44" 2 stage blower #79361 questions
   / 44" 2 stage blower #79361 questions #1
monkers
I have a 520H with a 2 stage blower I bought used, model #79361 I have some questions about the idler pulleys. Does anyone have the diameters of the flt and V idlers?
Mine look to have been replaced, and Im not certain they are correct, or the belt. Is the belt 5/8" x 68"? The little "L" bracket that is meant to keep the belt from coming off the flat idler has a lot of room between itself and the pulley, like the pulley should be larger diameter. Also, when I raise the blower, the auger stops driving because of the slack in the belt, looks like the belt should be a couple inches shorter. I have no problem taking that little L bracket off as its far enough away from the pulley that the belt could come off anyway. Im trying to find an online parts drawing that I can print out, maybe that will help. Im not certain if the pulleys were relplaced with the right ones or not, there are no numbers on them... Thank you
   / 44" 2 stage blower #79361 questions #2
https://lookup3.toro.com/request/request.cfm
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
1996 Ingersoll-Rand VR642C (A47477)
1996...
2017 TOP HAT TRAILER 16 FOOT UTILITY TRAILER (A53843)
2017 TOP HAT...
Light Tower (A52377)
2013 FORD F-550 (A53843)
2013 FORD F-550...
