4344 starting problem
/ 4344 starting problem #1
Sackett2
Platinum Member
Eugene, Oregon
Montana 4344HST
Well, I have one working hour on the Montana and have a I have a issue.
First I have no owners manual. It will be sent to me this week.
After doing some playing around, I parked it and the wife asked a question. I went to restart the tractor and the lights go on but the starter doesn't engage.
Now I am a certified auto tech, so this stuff doesn't scare me.
I jumped the wire to the starter solenoid and the tractor started up. I found a relay that "clicks" when the key is turned and tested it, it's OK. Its as if there is a safety lockout, stopping the start cycle.
If i had a wire diagram I could go a bit farther.
Is there anything basic I am overlooking that prevents the tractor from starting? if I had a manual I'd be looking up this information.
as a side note I discovered the seat safety switch has been cut/bypassed. Not bad for only 4 hours on it.
/ 4344 starting problem #2
Steve,
I know how frustrating it is to have the knowledge but lack the documentation (e.g., circuit diagram). But I think you've probably already identified the problem: a safety lockout.
Here are some possible lockouts you might not have thought of (various tractors will have various combinations of these lockouts): PTO must not be engaged, seat must have weight on it (you already checked this), transmission must not be in gear, brake must be on, clutch must be down...
With your knowledge and experience, you're ready to tear into it, but it's probably something simple.
And by the way, I'd recommend un-bypassing that seat safety switch. That's one safety switch I'd never disable.
I will properly fix the seat switch as soon as I solve the starting issue;
I already have a work around planned until I can figure it out.
It's a HST, so the clutch and trans are not a issue, the PTO switch I only just touched trying to solve the problem, the seat switch, didn't get voltage yet, that tells me something....
Wish I had a wire diagram...
Problem solved.
the PTO switch was moved from the "Interlock" (center position) to the "off" position, and it will not start there. The third position is the "Indep." position
Can someone enplane them to me?
I don't have a owners manual yet.:(
/ 4344 starting problem #6
Sackett2 said:
Problem solved.
Are sure you didn't say that backward? Surely the PTO switch was not in the "off" position when the tractor wouldn't start. The tractor should start only if the PTO switch is in the "off" position. They wouldn't want you starting the motor with a brush hog engaged, for example.
I believe your three switch positions are:
  • off - PTO is non-functional
  • on but with seat safety interlock switch included in the circuit (so if you're not on the seat, the PTO won't run
  • on but independent of the safety interlock switch included (so you can run a PTO driven water pump, for example, without having to put weight on the seat to defeat the safety switch)
I think the "interlock" and "indep." labels are a little confusing, but I can't think of any better short labels.
Oh, I know, it was in the "Off" position, and that is why I had the dash apart testing the circuits. Untill 6 hours later, I hadn't even had a need to try the PTO. The pto (on my tractor) will not run until you put it into the "indep" position, ( I'm learning about brush hogs and shear bolts now!)
I cannot tell you if I'm doing something wrong, the tractor is doing something wrong, or if we are both doing something correctly and the manual isn't in my hands to tell me...
I believe your definitions of the switches are what the dealer told me, however, I'm not sure they are acting correctly.
/ 4344 starting problem #8
Steve,
Are you sure you tried the PTO in the "Interlock" position when you were sitting on the seat? If you're not on the seat (or if for some other reason the seat safety switch isn't closed) the PTO would only run in the "Independent' position.
I wouldn't recommend running a brush hog or any other pull-behind PTO-driven equipment unless the switch is in the "Interlock" position and the seat safety switch is working properly. I'm not a safety nut, but this is a good safety feature that isn't inconvenient, so there's nothing to lose and a lot to be gained. The thought of getting run over by a brush hog or a roto-tiller gives me the creeps.
I will double check tomorrow, but I currently stand by my statements. if it isn't operating correctly, the seller will be hearing from me.
The seat currently is hot-wired on, and i will fix it tomorrow or Monday at work. I need to remove the safety switch from the seat so I can soder and heat shrink it correctly. Some Yahoo at a Southern Oregon dealership cut the safety switch on a 4 hour old piece of equipment that was up for sale. go figure.:mad:
thank you for your explanations of the systems; the tractor is making more sense to me every day.
OTOH, having the dash apart I have a good understanding of the electrical system and wires of this tractor now, I hope I don't have to use this information anymore...
/ 4344 starting problem #10
If I was you I would make the dealership get it all as original. I could see the dealership saying you were messing with the switched and wires so we are not going to cover it under warrentee. Leave it alone and let your dealer earn his keep under the warentee.
Montana, in my region of Oregon, doesn't have a dealership per say, but a sellership. Being a auto tech, the seller from Portland, expressed interest in me to do service work on the rigs in this area. I asked him about warranty work, he told me Montana would pay $75 an hour to local tractor Mechanics to do the work. I mentioned doing my own repairs (as opposed to trucking the tractor 150 miles) and he had no problem with this, in fact good possibility of Montana paying me when there is a warranty issue. I told him for my tractor, and small issues I just wanted a assurance that I wouldn't have to pay for a failed part.
Anyway, I'll deal with the seller with the seat issue and the pto question.
Now to fing a grade 3 bolt:rolleyes:
/ 4344 starting problem #12
There are several dealers on this site I was hoping one of them would jump in here. I think you might be wrong about the PTO positions if I am wrong hopefully one of them will correct me. I believe the positions are Off, Nothing happening with the PTO. The PTO switch has to be in this position before the tractor will start. Independent. Turn the switch to this position and the PTO comes on. ON the PTO is on but stops when you push in the clutch. I dont know how that works on a hydrostatic machine. Maybe maka or one of those guys can tell you.
ok, got the manual for the tractor.
By the manuals picture, written in Korean(?) it shows the off position as center position. The Tractor sold to us in the USA this is the intermediate position. So what I see is a error in the labels on the dash of the tractors. Skipro and Mota say both there tractors also will only start in the intermittent position.
That solves the why of the no-start and answers the question of the switch.
Steve
/ 4344 starting problem #14
Steve did you get a new better manual or is it the owners manual that comes with the tractor??
Roland
Steve
Roland
just the normal owners manual.
(2) FIFTH WHEEL PLATES (A65643)
(2) FIFTH WHEEL...
20ft Driveway Gates (A65579)
20ft Driveway...
2014 BMW 435i Convertible Coupe (A64557)
2014 BMW 435i...
2yd. Skid Steer Trash Hopper (A65640)
2yd. Skid Steer...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
KOMATSU PC 200 EXCAVATOR (A65643)
KOMATSU PC 200...
