4320 top link with I-match/ hooking up bush hog
   / 4320 top link with I-match/ hooking up bush hog #1
kicker
I have a bush hog brand brush cutter (72 "" squealer ) and everything hooks up nice in regards to the link pins but does the top link just float.
I adjusted it till the I-match accepted the link from the bush hog. does it just ride there and float. If I raise the bush hog all the way up it will slip off. I do have some type of parts to make the bush hog brand quick hitch compatabile but I am a mechanically challenge individual.
just curious
   / 4320 top link with I-match/ hooking up bush hog #2
I believe the third/top link is used only to control rotation of the implement. Therefore the lower links do all of the lifting. I would say as long as there is decent engagement on the upper link it will be fine being the i-match/quick hitch will keep it from slipping up and out. Hope this helps.
44029 (A51692)
44029 (A51692)
Giyi 40" Mini Sweeper (A53316)
Giyi 40" Mini...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2012 Bobcat E45 Mini Excavator (A55787)
2012 Bobcat E45...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A53421)
2015 Vermeer SC362...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A55787)
2018 Bobcat T590...
