4320 SCV
   / 4320 SCV #1
Lt220
Bronze Member
Dalton, GA
John Deere 3032E with rear hydraulics
Does anyone know if the loader SCV on a john deere tractor can be rebuilt? The valve has an internal leak in the spool that controls the dump and roll of my bucket.
   / 4320 SCV #3
Spool valves with internal leaks can't be repaired because spool & housing are a machined close tolerance fit IE complete valve assembly must be replaced. If leaking problem is caused by faulty check or relief valve then those can be replaced. Have you checked bucket cylinders to be sure their piston packings haven't failed?
   / 4320 SCV
Yes I know it's not the cylinders leaking because I can unhook the quick connects and it stops leaking. It's leaking down so bad that the bucket will be almost full dump in about 2-3 minutes
   / 4320 SCV #5
Does your tractors FEL have option of self leveling or regeneration valve on bucket circuit?
   / 4320 SCV
Thanks for the comments. I did some more tests today. I found O ring and seal fragments stuck in the male coupler of one of the hose that controls the bucket curl. After finding the fragments Im pretty sure it's a cylinder issue and not the SCV. I ordered rebuild kits for the cylinders.
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
199049 (A51243)
199049 (A51243)
(12) ROLLS OF WELDING WIRE (A51247)
(12) ROLLS OF...
2012 Honda Accord LX Sedan (A51694)
2012 Honda Accord...
2023 JOHN DEERE 3033R LOT IDENTIFIER 83 (A53084)
2023 JOHN DEERE...
