4310 Tilt Steering Locked Up
   / 4310 Tilt Steering Locked Up #1
HeyNow
Bronze Member
West Virginia
JD 4310
Has anyone here had any problems with their tilt steering locking up? Mine won't budge. I'm hoping that I can fix this myself in lieu of taking it to my dealer. Also, my fuel cap seems to be stripped. Does your fuel cap snug down or pop up after you hit bottom? Mine seems to pop back up indicating that it's stripped. I've replaced the cap once. I now think it is the tank.
Thanks for any input.
   / 4310 Tilt Steering Locked Up #2
I haven't had any problems with my gas cap but my tilt steering has locked up before. My tractor was still under warranty so I took it to the dealer. They were aware of problems with the tilt steering and there are replacement parts for the problem.
   / 4310 Tilt Steering Locked Up #3
HeyNow,
The tilt mechanism on my 4310 didn't work from day one. Same problem as the other fellow. Took it back to the dealer where they replaced something with a kit they get from JD. My guess is that is a common problem.
Steve Z
Thanks for the quick response. I guess I will take my unit back to the dealer. I'll miss her!
   / 4310 Tilt Steering Locked Up #5
Same problem and same result as the other two. There is a service bulletin on this, your dealer should fix you up lickety split...
   / 4310 Tilt Steering Locked Up #6
Try spraying a generous dose of silicon spray down around the tilt lever and working it until it slides freely. Mine needs that regularly. My hood hinge usually needs a good spritz of silicon too.
   / 4310 Tilt Steering Locked Up #7
</font><font color="blue" class="small">( around the tilt lever and working it until it slides freely )</font>
With mine there was no working the lever. The lever was froze. It would not move at all.
1459 (A57192)
1459 (A57192)
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2010 KMC 3376 Peanut Combine (A56435)
2010 KMC 3376...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
