4310 ePwrRevsr Clutch Problem
   / 4310 ePwrRevsr Clutch Problem #21
I had a very similar problem. Tractor would move forward normally, but reverse you sat there for a while before it finally would move.
Figuring I had lost a clutch seal, split the tractor. One seal was bad. Replaced all the seals and new fluid. Tractor would reverse a little quicker, but would not carry a load. Replaced the transmission controller, no change. When the wires were swapped on the solenoid and the tractor would reverse fine but die immediately and would not start until they were switched back. Just about to order new solenoids and transducers when I saw this post. Took out the pressure regulator valve and cleaned it well and the tractor worked better. Ordered a new one and now it is back to normal. 2002 JD 4310 Epower reverser.
Thanks for letting others know what solved the problem. Sorry you had to split your tractor.
KUBOTA L3800D TRACTOR (A57192)
KUBOTA L3800D...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
