4310 eHydro overfill transmission fluid duh!
   / 4310 eHydro overfill transmission fluid duh!
Thanks to all those who posted. Drove it, removed the BH and adjusted the rockshaft height, reattached the BH, played with the FEL and then parked on level ground. Oil is in the middle of the sight glass. I know I overfilled it by a couple of quarts but checked it a couple of times and it returns to the middle of the glass. Could this transmission hold more oil than normal? I didn't really measure the used oil but it sure seemed like there was more than 6.8 gal when it drained out. Could there have been air in the lines, etc and it finally bled off and settled down? Fairly new to a piece of equipment like this so still wondering.
   / 4310 eHydro overfill transmission fluid duh! #12
I remember adding more than what the manual called for on my first change. I added it over a period of time ( hours - with some use and allowing cooling and settling each time ) and it was indeed required to get it up to the glass level window. If I remember it took about a half gal extra.
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A56435)
2023 Kubota...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2014 Toro Groundsmaster 4500D Commercial Rotary Mower (A56857)
2014 Toro...
