4310 3 pt specs
/ 4310 3 pt specs #1
chickenman
where it says in the manual "Lift Capacity-61 cm (24 in.) Behind Link Arms (4310 and 4410) 999 kg (2200 lb)" , from where is this measured?
what exactly are the link arms, the detachable lower arms or the upper pivoting arms?
/ 4310 3 pt specs #2
chickenman,
they are referring to the lower 3ph link arms... where you would attach to the bottom 2 pins on a york rake or something. so, 24" from there, is what they refer to with that weight. most implements have the weight a bit behind those lift arms, depending on what implement.
what are you trying to lift back there?
/forums/images/graemlins/cool.gif
/ 4310 3 pt specs
im makeing a auger/post driver that will drill down about 12 feet or so, so i was wondering about the weight factor
/ 4310 3 pt specs #4
12 FEET!
wow... that's a long way down....
how far behind the tractor will this need to be?
that's what's going to be the problem, the further back you put the weight, the less performance you will have..
pictures will definately have to be in order if you get something like that going!
/ 4310 3 pt specs
i have to drill drainage holes down through a layer of clay that runs up to 8 feet thick to drain water from wet areas on my farm.
ill drill down through the clay and fill the holes with sand
the unit will be self contained with its own hydraulic system run off the pto with a hydraulic driven auger riding up and down a 16 foot I beam and a hydrolic winch to lift and lower the auger
take off the auger gearbox and slip on a 450 lb weight and it becomes a post driver
/ 4310 3 pt specs
ive looked into everything and decided it would be cheaper amd more convient in the long run to have the means to do the work myself at my convience
this will have to redone periodicaly
as the drains silt up
/ 4310 3 pt specs
ive got about $3600 invested so far
and still need metal, hoses , pto shaft and a couple more components
say farm, tractor or hydraulic and the price goes sky high
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
Brake Drums (A62613)
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
