4300 Died and Won't Crank
   / 4300 Died and Won't Crank #1
Grove JD
MO
JD 4300, 2555, 6200L & Kubota M5400
I was driving across a field and my 4300 HST died and won't restart. It died as if the key was shut off. The reason I say that is that it didn't sputter and die it just quit so I know it isn't an engine or fuel problem. The dash lights turn on and it has good voltage and good connections. I can activate the preheater it just won't crank. When I turn the key to the start position the K6 relay clicks but nothing else happens.
Please advise-
Grove
   / 4300 Died and Won't Crank #2
Have you checked the shutdown switches starting with the seat?
   / 4300 Died and Won't Crank #3
Could be the Operator Presence Switch under the seat...definitely look there first
Another potential would be the thermister...just do a search on TBN. Thermister failures were the bane of the old ('98-2005) 4xxx series Deeres
   / 4300 Died and Won't Crank #4
It definitely sounds like a safety switch somewhere.
Not sure it would be the seat switch or thermistor though as I can start my 4310 without sitting in the seat and I think the thermistor will keep it from starting but wouldn't shut it down if already running.
Checked all the safety switches to no avail. Finally checked each fuse with a test light and even though it looked ok the 10 amp interlock fuse was blown. Replaced and it fired right up. What does that fuse go to and what would blow it?
   / 4300 Died and Won't Crank #7
Good work on the fuse find.
I had the headlight fuse melt out the fuse holder block on my JD4200. Never did find out why.
   / 4300 Died and Won't Crank #8
YEs same thing happened to me, driving down a pasture with no loads and it just quit as if I turned it off. Same it was the 10 amp interlock fuse was blown. Looked good but wasn't and only found this issue after viewing this page/thread. Thanks for posting
   / 4300 Died and Won't Crank #10
slemonva
:welcome: to TBN
Do you have the part number for that fuse? tks
SET OF PRECAST STEPS (A58374)
SET OF PRECAST...
2020 MACK P164T (A58214)
2020 MACK P164T...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2000 TRAVIS BODY & TRAILER, INC. 39 END DUMP TRAILER (A58214)
2000 TRAVIS BODY &...
2006 Toyota Prius (A56859)
2006 Toyota Prius...
