427 BB Chevy problem
/ 427 BB Chevy problem #1
cp1969
Veteran Member
Kansas
Kubota L3000DT
I posted this on a Chevy forum today, but there are some pretty smart people here, too. I apologize if this is not the correct forum.
Hello, first time poster. This post is in relation to a friend's 66 427 Vette. I will try to explain to the best I can because this saga has spanned more than a decade.
Background: Friend bought the Vette in '95 with a newly "overhauled" engine. This engine burned a quart of oil every 200-300 miles, so he complained and was told if he'd furnish parts, they would do it over again. He did; and the result was the same 200-300 miles per quart.
We took the top end apart and found liquid oil everywhere in the intake manifold, so much that when tipped up on end, a big puddle formed around it. It looked like the exhaust crossover had more oil in it than anywhere.
He then had to take a temporary job in California and took the car with him. While out there, he contracted with an engine builder in Livermore to overhaul it "right." Something like $7K later, he gets it back and guess what--same story. That overhaul took place in '99 and he has put roughly 5K miles on it. On the dyno, it made 445 hp and something like 435 ft-lb (which I don't consider to be especially good numbers).
The California overhaul replaced everything on the engine except the block, intake manifold, and valve covers. New .070" oversize hyper eutectic pistons, new rods, new crank, new cam. The block was decked and align bored. The heads that were on it were replaced with the correct ones for that year.
I stopped at his house today and he mentioned he had a problem with his brakes and in the course of diagnosing that, I found out that when the vacuum hose is pulled out of the brake booster, it made absolutely no difference in the way the engine ran. I put my thumb over the hose and it is certainly pulling vacuum, but whether thumb is over the hose or not, makes zero difference in engine idle speed or quality. Out of curiosity, I pulled the PCV hose off the base of the carb and sure enough, that made a difference but the power brake vacuum line doesn't. That's odd. That is what prompted me to ask (again) how the oil consumption was doing and how the spark plugs looked. We pulled #1,2, and 5 plugs. #1 and 2 were a complete mess--black, with oily carbon covering everything. #5 resembled only faintly a normal plug in that the tip of the electrode was brown but the ceramic insulator was black once you got more than 1/4" away from the tip. About 1500 miles on these plugs.
When we had it running to test the vacuum booster, even with doors open at each end of his garage and with a slight breeze blowing through, the exhaust fumes were punishing--it was running so rich you couldn't stand more than a minute or two inside with it. I asked "Do you even have jets in this thing?" and he produced a record which said he has 69's in the primary and 76's in the secondary. I have no idea what size the factory jets were. His record also showed that he and another friend had experimented with changing jet size and had gone down to 65's but then returned to 69's as being "best". I can't imagine that this jetting is correct.
In summary, engine has everything new in it except block, intake, and valve covers. Another bit of info: the drip rails have been removed from the valve covers to clear roller rockers.
I have a hypothesis as to what's wrong but I don't want to pollute anybody's thinking as to what is wrong with this engine.
Any and all help will be greatly appreciated.
Thanks.
/ 427 BB Chevy problem #2
does the oil smell like it has gas in it? if so it could be that it is running so rich that the gas is actuallly washing down the cylinder walls preventing the rings from seating?? its really hard to diagnose over the internet,let us know how it worksout
/ 427 BB Chevy problem #3
If there isn"t a baffle inside the valve where the pvc valve goes the oil squirting out of rocker will go through the pvc and into the intake.. One other thing to look at is how the intake mates to the head. If the block has been decked and the heads milled the intake may need to be milled also. if the intake isn't down far enough it will suck oil at the bottom of the gasket
/ 427 BB Chevy problem #4
Interesting! I'm playing with a 406 in a ferrari 365 kit car and it seems to be doing about the same with the mileage at the 2500 mark. The short block was built for a stock car all I did was add heads and intake and carb. I don't have power brakes or any other power assists to draw down and I haven't been able to put a handle on it. I hope to do a leak down test on it next week to see what's going on in that department but this thing is baffling me. Many of my friends just tell me to go back to a mopar engine for it but I liked all the aluminum light weight stuff with the chevy at lower prices and the car was originally built around the chevy parts.
/ 427 BB Chevy problem #5
1, 2 and 5 are fouling. ?
no vacuum signal to speak of?
burning oil?
like HP said, look around the intake manifold. if they've machined it enough the angle of the V between the heads and the intake manifold could be compromised and isn't sealing around the bottom of the joint between manifold and heads.
burning oil?
Bingo. That is my theory, too--that the intake is leaking on the underside, drawing oil mist into the cylinders. The leak is probably worse towards the front of the engine than towards the rear. It makes sense--a big leak would require bigger jets to compensate, plus it runs poorly. Decking the block (which was done) may not change the angle between the heads and intake but it does move the heads down on the intake manifold.
All the plugs foul, with the fouling being worse towards the front of the engine. We only took out 1,2,&5.
It does have manifold vacuum--I didn't have a gauge to tell how much but you can definitely feel and hear it.
/ 427 BB Chevy problem #7
Sounds like a " race " motor vs a street version. I think the rings haven't seated ( were the cylinders cross hatched ) and very possibly a gasket leak someplace. Built properly these motors are bullet proof but it depends largely on the application. Did you complete a compression / leak down test and compare results ? Another item to try is the timing could be off 180 degrees. I had this problem years back where it ran hot, had vacuum issues, and ate spark plugs. Be sure to let us know the results. I also have a 425 hp coupe which was a former quarter mile star.
/ 427 BB Chevy problem #8
The jetting doesn't seem to far off if it is an 850. I looked back in my log books and when I was running a 440 (427+.060) it was jetted 78-79. I would guess you have blown a power valve in the carb and that is what is making it so rich at idle. Is there gaskets on the front and rear of the intake or was silicone used. If they used gaskets that may be holding the intake up to high.We always use RightStuff. If they used silicone, look and see how thick it is.That will tell you if the intake needs milled. Deckin the block and head will not change the angle between the intake and head just the height. Some times you can use a thicker intake gasket to correct the problem. What kind of oil was used during break in. Synthetic will keep the rings from seating. It is great after break in but not before. A BBC will not run 180 deg. out
Thanks for all the help. I had a hunch I might get better response here than at the Chevy forum and so far that has been true.
I don't have ready access to the car so can't answer some questions. I do know there have been a variety of oils tried but no synthetics. Everything from straight 30w to 15w-40 has been tried; currently has Castrol GTX 10w-30 in it. Changing weights, brands, etc. made no difference in oil consumption.
I really do not believe the rings are a factor in this simply because it's had three sets (along with three sets of pistons) and the oil consumption has remained constant. I would bet my last dollar that the short block is fine--the problem is elsewhere.
Only three components (block, intake, and valve covers--four total parts) are common to this sad tale of engine woe.
Block--I can think of no place in the block where a defect could cause oil to get in the cylinders. Correct me if I'm wrong.
Valve covers--Other than the missing drip rails, they are stock. Someone asked about a baffle under the PCV and it has one. I don't know what function the drip rails perform but surely it is not oil consumption.
Intake--I won't even speculate here, but he is really the only suspect left in the room. The question is, how to verify?
Thanks again for the help. Maybe we'll get to the bottom of this before my friend throws in the towel. He is so frustrated with this car he just wants to get rid of it right now. I asked him, "If it used a quart every 1000 miles and the exhaust didn't burn your eyes like mustard gas, would you still want to sell?" and the answer was absolutely not. It is a beautiful car--a black roadster that looks like it came off the showroom floor. He's done some things to it that I think detract from the character of the car, such as put in 4:11 gears which I think limit top end to something like 119mph. He took out and disposed of 3:55's which I think would have been marginally high themselves--I'd think 3.23's would be about right with all the torque that this thing ought to produce, but he has his own ideas about what he wants.
/ 427 BB Chevy problem #10
I vote for intake not sealing...maybe its not a good fit, milled too much. I'd remove it and look at gasket pattern. It should be easy to see if its not sealing by impressions left behind.
Would be nice to have the benefit of using a "smoke machine" for a diagnosis aid...Id inject smoke into the intake brake vac hose and see if it comes out the oil fill hole with fervor.
If you dont have a smoke machine maybe you and 12 buddies with a box of cigars could blow hits into the hose>>>LOL (take pictures if you do that!!)
/ 427 BB Chevy problem #11
I agree with the othes that a check of the machining surfaces needs to be done to see if the intake was machined to match. However, the first thing's I would do are a leak down test to verify cylinder integrity. Next I would fill the crankcase full of smoke from my smoke machine and see if and where it comes out of. If smoke starts to come out of the carb, you found the problem, intake to block sealing surface.
I had a similar problem in a brand new W4500 Chevrolet cab over truck with a 350 Chevrolet small block. Nasty oily plugs, bad oil consumption at around 1 quart every 200-300 miles and poor performance. What I found was that the rings had been installed upside down at the factory. That's right, rings were installed upside down from the GM factory. Long story short, since it was a commercial truck owned by a commercial client GM payed to have a new motor installed. I ended up getting the old engine that had less than 2,500 miles on it. Pulled it apart and stuck a new set of rings in it right side up and sold it to a friend of mine. Has been powering a friends P/U truck for a couple of years now and works great. Got to love factory screw up's.
/ 427 BB Chevy problem #12
I have a 66 with a 69 motor in it. (smallblock)
The original aluminum 66 valve covers didn't have a place for a pcv to be installed, but the 69 did. The 66 used the downdraft tube to rid pressure from the crankcase.
Is there a chance your sucking oil from your lifters and sending them right to the carbs?
My brother told me about a '53 sitting behind a friends barn out in Arkansas. Seems everyone knows where there is an original '53 sitting. He mentioned it again six months later, so I went and got my picture book and made him pick out the right body style. He did, then mentioned it was a V-8, which put it at '55. I tried to call the guy, but no luck finding his number. About a year later I went out there, found out he moved to town, and located his number. Finally got ahold of him, only to find out that yes, his Dad's old '55 sat out back of the barn, with the top and interior in terrible shape, but it did turn over when they stuck a hot battery to it. Since interiors were done by my inlaws for a living, I was sick. Then he told me a guy from Dallas bought it for $500, about six months ago, I really was sick.
Point is, he also had a 67 motor, 427 with the tri-carbs on it, for a grand.
It is probably sold by now, but if I had the money, insight, I could probably have made some change off that deal.
Guess I will go out to the garage and sit in my toy and forget about missing deals.
David from jax
This isn't the tri-power engine; it has a single Holley. But, yes, that is the area in which I'm concentrating--a leaking intake.
We've devised a test that may or may not prove this. The plan is to remove all the intake pushrods, remove the carb and block it off with a plate, block the power brake vacuum line and then use either vacuum or a leak-down pressure test on the manifold to see if it has gross leaks. Of course, leakage by the valve guides might blow this test out of the water but I think we're looking for much worse leak(s) than can get by the valve guides.
/ 427 BB Chevy problem #14
Use vacuum if you can. Air pressure will try to open the valve and vacuum will try to close them. One more thing I thought about. Since it has a PVC valve it should have a breather on the other valve cover. Another thing, does it have the stock dipstick. If it has a chrome aftermarket one it may be way off(over full).Do you know how much oil is in it. It should hold 5qts with filter.
/ 427 BB Chevy problem #15
Did your friend put the intake on or did the machine shop. 427's used 2 different port designs. oval and rectangle. You can run an intake with an oval port on heads with rectangle ports but not rectangle intake on oval heads. And both take different gaskets.
It's the stock dipstick and rectangular port heads with rectangular port intake.
I'm thinking like you are, that vacuum might work better than pressure.
Thanks for the help.
/ 427 BB Chevy problem #17
Spray some starting fluid arounf the intake at idle and see if the RPM's go up. If so bad seal between the 2.
/ 427 BB Chevy problem #18
Thats an ok, yet not really fire safety conscious approach...If you are going to squirt flamables around- carb cleaner is a bit more precise with the nozzle straw and consistent acting than ether. A propane torch used for the gas only with the flame off of course and a hose for extension is even better. But these approaches wont tell you if the gasket is sucked in toward the intake valley under the intake, only if there is a sealing defect above.
JOHN DEERE 7320 TRACTOR (A64278)
JOHN DEERE 7320...
2024 CATERPILLAR CP56B PADFOOT ROLLER (A65053)
2024 CATERPILLAR...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2013 Ford Taurus AWD Sedan (A64557)
2013 Ford Taurus...
2022 EZ-GO ELITE...
JMR 4ft Tree Boom Skid Steer Attachment (A64553)
JMR 4ft Tree Boom...
