42" plow
   / 42" plow #1
MrWiggles2
Clarence Center, NY
2004 Cub Cadet 2180
I'm wondering here who has the 42" plow for the Cub 2000's and do you like it? Does it have enough downforce to plow some dirt/snow, or is it a waste? I've seen some used that were a lot cheaper than the $600 the dealer wants.
   / 42" plow #2
I've got a plow on one of the first AGS 2160 models. (I think is 42") The plow is basically for snow because the tractor can't push much. After some modifications to the tractor (filled the tires, added concrete, tire chain's) it will move some dirt. Then we added a hinge to disable the spring loaded blade trip. Now I can fill the blade about 1/2 full of sand. Its still not a real tractor but with some help the blade will move a little dirt if its loose.
I've made a number "modifications" to my cub it seems to be a pretty soild little machine. I have plenty of pictures if you are intrested.
   / 42" plow
Thanks a lot, I'll PM you with my email address. Pictures would be very helpful.
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
1992 Effer 7600 2S Knuckleboom (A51692)
1992 Effer 7600 2S...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
