410 / 4100 Hydraulics - Bad Instructions?
   / 410 / 4100 Hydraulics - Bad Instructions? #1
keeney
Veteran Member
Minnesota
JD 4100 HST
To save a few dollars, I picked up my new 410 loader for my 4100 in a crate and installed it myself. Bolting the mount brackets on was not too bad, but there was some confusion with the hydraulic connections.
The instructions specified which connections on the loader went to each color coded-connection on the tractor. When I powered it up, the lift and bucket controls were swapped and also functioned reverse of what they should.
To get it to work right, I ended up copying the connections from my front blade.
I double checked the instructions, and I can only conclude that either the instructions are incorrect or the color-coded SCV connections on my tractor are plumbed differently than JD expects.
Here is what ended up working:
Yellow = Bucket Curl
Silver = Bucket Dump
Green = Lift Up
Black = Down
Is this the normal setup for the SCV?
- Rick
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
3ft Metal 5-Point Star (A55853)
3ft Metal 5-Point...
Adams 6Ton Hydraulic Lime Spreader (A57024)
Adams 6Ton...
UNUSED 1RANCH 1RGPM GROUND PROTECTION MATS (A57193)
UNUSED 1RANCH...
1421 (A57192)
1421 (A57192)
