4035 PST will not start
/ 4035 PST will not start #1
jnknsmk
Franklinton
2012 4035 PST
First time poster here- I went through the first five pages of posts and couldn't find my specific problem.
For a couple of years now, there have been times- random and unpredictable, but usually on first start after sitting for days or weeks- when I would have to "bump" the key switch several times to get the tractor to turn over and start. It would always eventually start. I always assumed starter switch. Now, it won't start at all. Still have to "bump" the key switch a few times to get the starter to engage, and when it does, the engine only partially turns over. It only makes a few degrees of rotation and that's it. With a brand new battery, the voltmeter needle only comes up about 25% and the red battery charge light is on.
Here's what I have tried so far:
1. New battery
2. New ground cable straight to the frame- tried engine block as well with no difference.
3. Took the starter to a highly reputable shop and they took it apart, inspected it and function checked it and said there is nothing wrong with it.
4. Tried a new key switch.
5. I've even wondered if the starter is trying to turn an engine that doesn't want to be turned, but I keep going back to electrical because of the voltmeter/ charge light.
Anybody have any helpful ideas? Thanks in advance!
/ 4035 PST will not start #2
Was it a shop that tested the starter in a test bench? Any hydraulic that block the flow and locks the pump?
/ 4035 PST will not start #3
My guess is a bad positive cable or other bad connection. If the charger is reading low voltage with a new battery it sounds like the battery lost clamp.
Several folks on TBN have had similar issues and found that cleaning cables and or replacing cables did the trick.
The shop tested it on a test bench and took it apart and inspected it. Guess I could crack the pressure line to check the hydraulics, right?
Also, the positive cable has been cleaned and is spotless. May need to consider changing it, though.
/ 4035 PST will not start #7
Most times when you bump the starter to get it turning over its the solenoid my:2cents:
/ 4035 PST will not start #8
Your positive cable could look brand new, and still be bad. The acidic gas coming from the battery will get inside the swaged connection between the connector that clamps onto the post and the actual copper in the cable going to the starter. This acid turns the copper into white dust, with at least a layer of this white dust keeping the full battery current to flow to the starter terminal. You can check this by applying a voltmeter from the positive post on the battery [ not the clamp ] directly to the post the cable hooks onto on the solenoid. When you turn the key, you should read little voltage between these two spots. I had a JD2240 that acted like yours, which had a bad safety switch at the top of the trans that was made by the 'range' position of the trans. I put a push button across this switch and it allowed full current to the solenoid to pull it in. So, if not the positive cable, make sure you are getting full voltage to the coil of the solenoid.
/ 4035 PST will not start #9
Jump start it by connecting the hot cable of the donor vehicle to the positive battery feed on the starter. If it starts this eliminates the bad hot cable theory. If it doesn't start move the ground cable connection to the engine block or a starter mount bolt it you can access one. If it then starts you have confirmed the ground cable is bad. If it doesn't start and/or acts the same then we know the problem is elsewhere.
While the cables are attached, hot wire the starter terminal that the key switch is fastened to. If it then starts you have confirmed the problem is the switch circuit not telling the starter to engage. If it doesn't start you have now narrowed the problem down to the solenoid or starter.
Now move the hot cable connection from the donor vehicle to the hot terminal on the starter housing. If it starts you have confirmed the problem is in the solenoid. If it still doesn't start it has to be the starter.
/ 4035 PST will not start #10
Sounds like a bad new battery.
/ 4035 PST will not start #11
Sounds like the starter solenoid to me.....every time you bump the key, you reactivate the solenoid until eventually contact is good enough to pass the current required to activate the starter motor.
You need to get a voltmeter, and do measurements at a few places along the circuit. Check if voltage is dropping right at the starter positive terminal, and if it is, then work your way back from there to find the source of the voltage drop. Will require 2 people or long leads and some alligator clips.
/ 4035 PST will not start #12
Hard to start looking at a bunch of different items when the OP’s battery charger is reading low battery voltage......with a new new battery it’s unlikely that’s the cause- especially since the new and old battery present the same symptoms. The other cause for the charger to read low voltage is a bad connection as 99% of the time the charger clamps to the battery cable and not the post itself.
/ 4035 PST will not start #13
I have a 4510, it turned out to have a bad battery cable internally.
/ 4035 PST will not start #14
Mine did the same thing. Turned out to be the connector to the alternator was not plug all the way in. Check it out might me the problem.
Well, guys, I guess since I don't know any of you, I can come clean. It was the PTO switch. Not that it was bad, IT WAS ON!!! I guess the light was hidden behind one of the steering wheel arms and I just never saw it in the daytime. Once I saw the light, pushed the button, and the light went out- VROOOM! Fired right up. I thing there is still something wrong with that switch since it does allow the engine to try to start.
I'm just glad I can avoid the embarrassment by not opening this thread again. Thanks, anyway guys!
/ 4035 PST will not start #17
This happened to me and the ignition switch itself was bad.
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
2021 CHEVROLET TAHOE (A66091)
2021 CHEVROLET...
2006 TANKCON FRP INC. 130BBL FIBERGLASS ACID TRAILER (A67714)
2006 TANKCON FRP...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
