401c hydraulic pump removal
   / 401c hydraulic pump removal #1
bigbadjohn
John Deere 401c
i just purchased a 401c skip loader, the front hydraulic pump has a leak, i can't figure out how to remove it. is the shaft just supposed to slide off? I tried removing the radiator but failed at that also, it seems like something on or near the bottom of the radiator is not allowing it to move. I also could not remove the drive shaft, from the pump to the engine, i removed a couple bolts on a split connector but that didn't work either,,, any ideas?
City of Buckhannon - 2000 GMC 3500 Service Truck (A52384)
City of Buckhannon...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2023 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2023 SMITH...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
