4010 54" MMM
/ 4010 54" MMM #1
cdgilbert
Darlington, MD
John Deere 4010
4010 54\" MMM
Gang:
Just wanted to let you know of a recently discovered problem with my MMM.
After firing up the mower for the first time this season, I noticed the tractor was lugging a bit more than usual. This was followed by a good deal of white smoke emanating from the mower deck. /forums/images/graemlins/shocked.gif I immediately removed power to the PTO.
The smoke was caused by the drive belt rubbing into the left side pulley housing shield and buring the paint off. The idler arm bushing had seized, causing the belt to pop off of one of blade pulleys. The seizure was caused by too much green paint on the upper and lower mating surfaces of the idler arm bushing. I removed the excess paint, cleaned and reamed the idler arm shaft/bushing and re-lubed the entire assy. This problem was acknowledged by my dealer and after some negotiation, they agreed to provide me with a new belt.
You may want to check your idler assemblies and verify that they are freely pivoting.
Cal
/ 4010 54" MMM #2
Re: 4010 54\" MMM
How many seasons has this deck been running?
/ 4010 54" MMM
Re: 4010 54\" MMM
I took delivery of the tractor with the mmm in July of '04 and
have about 20 hrs of cutting time with the mower.
I have greased the all the fittings on the deck at least 3 times.
Cal
LADDERS (A68842)
LADDERS (A68842)
2005 INTERNATIONAL 9400I (A67714)
2005 INTERNATIONAL...
2025 48in Rotary Brush Cutter Mini Skid Steer Attachment (A66734)
2025 48in Rotary...
40 YD ROLL OFF DUMPSTER (A67714)
40 YD ROLL OFF...
2006 Ford F-350 Crew Cab MOT Safety Truck (A66736)
2006 Ford F-350...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2018 Ram 1500 4x4...
