400x Loader
   / 400x Loader #1
CUTnRAY
My bucket level indicator fell off on my 400x . The bolt holding the cylinder was still in place but the nut was missing.The parts person at the dealership said 3 washers were also missing, but when I put the thing back together there was no way that the washers would fit and still have enough threads on the bolt so I only installed the nut although seems it could easily come apart again as it will not stay tight. Has anyone else had this problem? The tractor is a 4520.
   / 400x Loader #2
The dealer is right, there are three washers that go on the bolt then the indicator goes over them, reason for the washers is that they space the nut out far enough to allow the indicator to swivel, if it were tight then it would bend and something would have to give. I am guessing that it may not have been torqued when it was setup at the dealer, I went out to break mine loose and you could tell mine was torqued
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
