400CX or 400X for JD 4720?
   / 400CX or 400X for JD 4720? #1
FRIZ
Bronze Member
NW Indiana
John Deere 4720 Cab
Hi everybody:
What is the difference between the 400CX and 400X? Obviously self leveling. Anything else? Is there a disadvantage to self leveling? Is the self leveling worth the approximately $600 difference in price?
Please clarify for me.
Regards,
FRIZ
   / 400CX or 400X for JD 4720? #2
I don't think I've seen anyone regret getting the CX upgrade, in your shoes with a $40k base price for a cab 4720 I'd probably go for an extra $600 - especially if you want to get pallet forks.
   / 400CX or 400X for JD 4720? #3
400 CX is supposed to add several hundred pounds of lifting capacity and be self leveling.
   / 400CX or 400X for JD 4720? #4
Higher lift capacity. According to the original press the CX boom was heavier material.
Downside is that the rollback on the bucket does not appear to increase as FEL is elevated. Rollback is nearly the same for both, but as you raise the 400X the bucket appears to tip back thus holding material in better. The CX does not do this, thus carrying a heaped load equals spreading the material.
   / 400CX or 400X for JD 4720? #5
Self leveling buckets work well from my use.
Cidertom, how high do you have your loader bucket when transporting? I keep mine low to the ground ( leaving clearance).
Steve
   / 400CX or 400X for JD 4720? #6
Steve
Transport height is about a foot.
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2013 John Deere 4730 Self-Propelled Sprayer (A51039)
2013 John Deere...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Miller Bobcat 225G AC/DC Welder Generator Set (A49461)
Miller Bobcat 225G...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
