4-wheeler's trick applied to tractors
   / 4-wheeler's trick applied to tractors #1
RanchMan
Platinum Member
Texas
Mahindra 4110
4-wheeler\'s trick applied to tractors
Here's a goofy little "Jeep" trick I applied to "tractoring" the other day -- Not sure if it has been posted here in the past, but thought I'd go ahead and post it anywho.
I was using the box blade (low gears - VERY slow) and had just stopped making forward progress (rear dif locked, all 4 wheels still slowly turning though).
Anyway, an old Jeeping trick for a "stuck" situation is to turn your steering wheel back and forth a couple of times while the wheels turn. I tried it and sure enough, works for tractors too. /w3tcompact/icons/smile.gif The tractor tarted creeping forward once again and I was able to avoid even pushing in the clutch - much less throwing it in to reverse.
Of course, this trick is useless unless you have a 4wd tractor. /w3tcompact/icons/frown.gif
   / 4-wheeler's trick applied to tractors #2
Re: 4-wheeler\'s trick applied to tractors
I've used that trick a time or 2 myself, both with my pick-up and my tractor. Great when you just need that little extra bit of traction.
   / 4-wheeler's trick applied to tractors #3
great trick, I probably already do it naturally but maybe it will come to mind next time i get stuck
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
Hyster H225E (A47384)
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
