I have a JD425 AWS that is just awesome. BTW, my back wheels are larger than my front ones. I mow a 20 degree incline sideways without any fear of tipping. I would say that when coupled with a hydrostatic tranny, that AWS can't be beat for traction, stability, and certainly manueverability.
And for snow removal, AWS with my power front mount dozer blade will run circles around most other snow machines, even those much larger. I can plow sides even on narrow driveways, or straight ahead, and when close around cars, and buildings with incredible efficiency. I have a friend who has the same model tractor as mine but without AWS. He says his won't push more than about 8" of heavy snow very effectively. In contrast, I've pushed snows as deep as 25" without any problem at all, even uphill. I think at least part of that is due to the AWS.
The only negatives with AWS:
Can tear your grass if tractor is heavy - always turn while in motion, avoid turning while stationary.
Generally less ground clearance. My tractor is heavy and powerful enough to pull implements. But, the ground clearance limits what I can do, especially in broken soil. On my particular tractor the ground clearance on a non-AWS is more than double the AWS model.
There are some new models out that offer nearly the same turning radius' without being AWS. These might be worth a look. But, there is little not to like about AWS.
