4 Wheel Drive Will Not Engage (3510I with Loader)
   / 4 Wheel Drive Will Not Engage (3510I with Loader) #1
knaussp
I recently purchased a 3510i with 383 hours. I did not test the four wheel drive at the time of purchase, but was assured that it worked. I have since used the tractor and am unable to engage the four wheel drive. Can you provide specific guidance on engaging / testing this tractors four wheel drive feature.
Additionally, I intend to use it to bush hog on a very steep levy near Memphis. The soil is very soft and it is difficult to maintain traction. Suggestions to improve traction beyond the 4 wheel drive issue would are appreciated as well.
   / 4 Wheel Drive Will Not Engage (3510I with Loader) #2
You can usually just rock back and forth the tractor real gently and it will slip into 4wd...If u dont know much about the tractor could be the linkage is rusted up. Sometimes they are a little stubborn about going in or coming out.
On you other question...DONT....the 3510 is a great little tractor but keep it off steep grades..THEY WILL TURN OVER. When I am doing any work with much of a grade at home I use my other tractor a 2000 series Ford..it has a wide stance and feels good on the hills but not the 3510.
With that being said if and only if you can go straight up and down with a good place to turn at top and bottom would I consider using the 3510.
Be safe
   / 4 Wheel Drive Will Not Engage (3510I with Loader) #3
You might also try using the front end loader to lift the front wheels off the ground a bit. This takes out all binding and lets it slip right in. I do this most times as I park on concrete and it will bind up just backing it into the barn....Kong
Great suggestions. I'll try rocking and using the loader. Also, yes, I will plan on straight up/straight down on the slope. I looked at Ford 2000 tractors but was afraid that a 2wd wouldn't get it done on the slope.
   / 4 Wheel Drive Will Not Engage (3510I with Loader) #5
You would be surprised where a 2wd tractor will go especially with chains on. I rarely have my Branson out of 4WD...it wont go anywhere in 2wd
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
2024 78in Screening Bucket Skid Steer Attachment (A51691)
2024 78in...
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
