4 wheel drive on kubota L3710
   / 4 wheel drive on kubota L3710 #1
jimmachinist
Meadville Pa
Kuboya L3710
I can't get my 4 wheel drive to engage on my L3710. The lever used to be difficult to put in and out of gear. Now there isn't any pressure moving it either way. It doesn't just flop around it stays up or down where ever you put it, but it just won't engage. Any ideas?
   / 4 wheel drive on kubota L3710 #2
With any luck, it's external to the transmission... just something in the linkage... easy to diagnose and fix. If needed, clean up the underside enough so you can see what's going on under there, get out the creeper and a flashlight and have a look. Make sure the keys are in your pocket and the brakes are set, of course!
   / 4 wheel drive on kubota L3710 #3
Did it work before when moving the lever? There has not been any problems with them! It must be a simple problem.
   / 4 wheel drive on kubota L3710 #4
On these models the front drive shaft is partly internal to the transmission. There's a forward section with an outer cover that can be slid back to expose the couplings. Start there to see what's connected and turning when the front wheels turn.
   / 4 wheel drive on kubota L3710 #5
Have you looked under the tractor at what the lever actually moves?
2023 JOHN DEERE 8R370 LOT NUMBER 219 (A53084)
2023 JOHN DEERE...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53472)
2003 International...
New/Unused Self Dumping Hopper (A51573)
New/Unused Self...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
