4 wheel dr
   / 4 wheel dr #1
oldman57
pueblo west co
jd 3320/cat 242 skid steer
hello
just bought a jd 3320 4x4
just one question how do you put it in 4wheel dr
i put the leaver in the up position ,its the leaver just above the e brake the lite on the dash lites up, but the front tires dont move
any idea thanks
   / 4 wheel dr #2
If the 4 wheel drive indicator is lit, you are in 4 wheel drive. Not sure what you mean. Are the front wheels locked up, skidding while the rear wheels turn? Have you checked the front axle for fluid level? Be sure the tractor is in gear (e hydro range selector is easy to disengage). Let us know how it turns out. The 3x20 series are great machines.
   / 4 wheel dr
when i raise the front end up ,and go forward or backwards the front wheels dont move when in 4 wheel dr. aren't they suppose to turn
thanks
   / 4 wheel dr #4
Are you saying they drag? AS I'm new to 4wd tractors, but something sounds very wrong. Do they turn when your in 2wd?
   / 4 wheel dr
hello,
yes they roll back in forth , but when i lower the bucket down, an raise the front end off the ground and move forward & back in 4x4 the wheels dont roll
they should roll when in 4x4.
talked to the john deere dealer an he's going to take a look at it
i checked the 4x4 leaver an it's moving, the lite on the dash is lit when i ingage the 4x4
thanks
   / 4 wheel dr #6
Yea, think you are on to something there, if everything is right they should be turning when up in the air....
--->Paul
   / 4 wheel dr #7
Are you looking at both sides? They are not positract so only one side may be turning. With the wheels lifted and 4 WD engaged , can you hold one side so it doesnt turn and then turn the other wheel by hand? If you can then something is not engaged properly.
   / 4 wheel dr #8
Put it in 4wd and lift it so ONE wheel only is in the air, then try to turn it by hand. If it will spin, then you have a problem.
   / 4 wheel dr
find my problem broken driveshaft ,
thanks
   / 4 wheel dr
not a cheap repair i take it, just put a call into the place i bought it from
thanks guys
2011 PETERBILT 389 (A52472)
2011 PETERBILT 389...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
(2) Hydraulic Augers (A50121)
(2) Hydraulic...
Super Material Lift MH1000 (A52748)
Super Material...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2014 Ford F-150...
2012 Ford Fusion SE Sedan (A50324)
2012 Ford Fusion...
