4 Way Valve Problem
   / 4 Way Valve Problem #1
My442
The 4 way valve on my BX2200 loader does not work for the up/down function.
The bucket tilt works fine.
Any suggestions?
   / 4 Way Valve Problem #2
Any suggestions?
Check your quick connects. Might not be fully seated.
   / 4 Way Valve Problem #3
Check to see that your coupler tips for raise & lower are correctly seated together. I see this happen quit frequently.
Also see that you are moving the spool in your control valve.
   / 4 Way Valve Problem #4
Is your relief coming on when you try to lift?
Does the loader move either up or down, or half way?
Reset the QD's and make sure your spools are actually moving.
   / 4 Way Valve Problem #5
What was the outcome of your problem.
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
Brent 776 Grain Cart (A50514)
Brent 776 Grain...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
IH 810-10 Pick Up Head (A50514)
IH 810-10 Pick Up...
