4 way flasher
   / 4 way flasher #1
Minimower75
1998 craftsman ez3 tractor
Hey all, im lookin to put a set of four way flashers on the rops of my mower, any suggestions??
   / 4 way flasher #2
On the Craftsman?:laughing::confused:
   / 4 way flasher
Yeh lol its just a lil project . Im paintin it cat yellow with the cat color scheme, dubbed the LM46D , its gettin a rops, and it has a exhaust stack
   / 4 way flasher #4
I would guess you need a 12 V 2 pin flasher and a single pole toggle switch. Some automotive grade wire #14 AWG some 1/4 " wire loom and some tie wraps. Lights in your basic orange. And a fused source or a quality inline fuse. That should complete the shopping list.
Craig Clayton
   / 4 way flasher
And how would i go about assembling this?
   / 4 way flasher #6
Craig Clayton
That about sums it up:laughing:I might suggest LED lights w/built in flash module. They are pretty cheap, easy to install and most importantly showy.;)No need for that tricky 12 V 2 pin flasher:D
   / 4 way flasher
Well i ment puttin it together and where would i find one with it built in
   / 4 way flasher #8
Try ecco light systems. Code 3 makes lights. That's all I've got, off the top of my head.
   / 4 way flasher
Aight thanks man
   / 4 way flasher #10
It might be a little silly when overdone (and I admit to overdoing) but there's good sense in warning lights when mowing on the edge of the road or when driving the machine down the street to the neighbors yard.
I agree on looking at Ecco and Code 3. Also, Tractor supply sells an amber dual rotator for $100 or a LED beacon for $50. Sirennet.com and AW Direct sell all kinds of cool stuff to look at including flashers you can wire up to whatever you want. Just search "amber warning light" or something like that and you will find everything from inexpensive items from far off lands to very expensive items intended for plow trucks and wreckers.
The local truckstop will surely have an assortment of lights you can use. The two sided markers used as turn signals on the fenders of big rigs would look good on the ROPS.
In the interest of overdoing, I just bought a Whelen M9 light bar on eBay. It's got 6 strobes, and has 2 work lights on both the front and back. The outfit I bought it from is a place in TX that rebuilds Whelen bars and sells them at a fraction of the price of a new one. It's not exactly cheap, but it'll definitely look a lot better than something I cobble together from stuff from the auto parts store or truck stop. Having the warning lights and work lights integrated into one unit will look nifty.
Have fun but make sure you don't overload the electrical system. I upgraded to the 40 amp alternator on mine just so I can run lots of lights.
LEDs are more efficient, but cost a heck of a lot more than similar halogen or incandescent units.
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2016 JLG 2646ES 26ft Scissor Lift (A50322)
2016 JLG 2646ES...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
80in HD Tooth...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
