4 ring or 5 ring piston...does it matter on rebuild of AD3-152?
   / 4 ring or 5 ring piston...does it matter on rebuild of AD3-152? #1
Rford
KC
1966 Ford 2000 Diesel 8sp
Called the MF dealership to talk about inframe rebuild kits and the salesman talked me out of ordering OE Perkins in lieu of a PowerMax kit. It was $320, arrived in a couple of days, and it looks like it is all there, in fact, it looks to me like they sent me two extra sets of main bearings.
I have the odd-ball CE22666 build no. engine but the PowerMax manual had this listed. I noticed right off that the new pistons are 5 ring, not 4 ring. The pistons are the correct size but they have an extra oil ring below the wrist pin. The service manual shows 5 rings and not 4 and even mentions the extra ring as "Maxigroove" oil ring. So I'm thinking 4 rings or 5 is not important, probably an upgrade from 4 to 5 at one time.
Any experts on the "Maxigroove" oil ring out there? Would this cause anyone a concern?
   / 4 ring or 5 ring piston...does it matter on rebuild of AD3-152? #2
Most naturally aspirated Perkins used 5 ring pistons, turbocharged used 4 rings, you should be OK with what you have, 5th ring helps oil control.
Thanks...oil control will be good...it had major blow-by and oil shooting out of everywhere before the teardown....
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
