4 in 1 430 Loader
   / 4 in 1 430 Loader #1
walls1
Hello,
Does John Deere make a 430 loader with a 4 in 1 bucket attachment? I assume this would fairly expensive. I priced a standard 430 loader and the price was $2875.
Thanks,
Bill Walls
   / 4 in 1 430 Loader #2
Re: 4 in 1 430 Loader by John Deere
Yes...
PC 2664-410, 420, 430 AND 460 LOADERS ATTACHMENTS
4-IN-1 BUCKET
KEY PART NO. PART NAME QTY SERIAL NO. 0 0 REMARKS
1 JD7797 LUBRICATION FITTING 6 X X
2 W45744 REINFORCEMENT 2 X X
3 W45746 CUTTING EDGE 1 X X
4 W11955 LOCK NUT 2 X X
5 19H2762 CAP SCREW 2 X X 5/16" X 2-1/4"
6 W45741 PIN 2 X X
7 W45742 REINFORCEMENT 2 X X
8 AW30190 LOADER BUCKET 1 X X (FRONT)
9 W45745 CUTTING EDGE 1 X X
10 T77814 O-RING 6 X X
11 38H1204 TEE FITTING 2 X X
12 AW30195 HYDRAULIC HOSE 2 X X
13 AW30192 PIN 2 X X
14 19H2997 CAP SCREW 4 X X 3/8" X 1-1/8"
15 AW30191 LOADER BUCKET 1 X X (REAR)
16 W45747 CUTTING EDGE 1 X X
17 R76477 TIE BAND 4 X X
18 AW30196 HYDRAULIC HOSE 2 X X
19 AW30197 HYDRAULIC HOSE 2 X X
20 W45743 SLEEVE 1 X X
21 AW30193 PIN 2 X X
22 K40003 LOCK NUT 4 X X
23 AW30194 CYLINDER 2 X X (SEE CYLINDER ASSEMBLY FOR BREAKDOWN)
24 BW14676 LOADER BUCKET 1 X X
25 W46060 DECAL 1 X X
26 W45736 LABEL 2 X X
27 AM102487 HYD. EXTERNAL HALF COUPLE 1 X X
28 M85099 CAP 1 X X
29 M70728 CAP 1 X X
30 AM102420 HYD. INTERNAL HALF COUPLE 1 X X
   / 4 in 1 430 Loader #3
John, what is the price on the 4n1 buckets with hyd solenoid kit. How many sizes do they come in? Can these buckets also be used on the 440 and 70 loaders?
thanks again,
george
   / 4 in 1 430 Loader #4
George,
Don't know nothing about pricing...check with local JD dealer... {couple thousand?} but I'm sure some 3rd. party mfrs. would be alot cheaper? I believe Dan has a 3rd. party 4 in 1 bucket on his 4700...
Good luck George.
   / 4 in 1 430 Loader #5
Hi Bill,
Here's the scoop on a "Long" 4n1 bucket I have on my 4700.
This is for a 72" bucket (model UJ2-72) -larger and heavier than you would need, but it will give you an idea of the prices-yours should be less.
bucket $1495
toothbar $262
Specify your loader type(430, ...mines a 460), and it will be made to fit slick-as-a-whistle.
Solid well-made bucket with an excellent rep., ..lots of discussion about them on this site, numerous happy users!
Phone (800) 823-4570 Speak to Vance. Very helpful!
HTH /w3tcompact/icons/smile.gif
Larry
   / 4 in 1 430 Loader #6
Bill,
Forgot to mention the selector-valve kit, ..$375.
Larry
   / 4 in 1 430 Loader #7
John's drawing looks like my 4n1 bucket so mine must be a JD implement. I've never known for sure if my 4n1 was a third party or JD implement. All I know for sure is it works real well and I use it all the time. /w3tcompact/icons/smile.gif
I had a nut come off one of the controlers that allows the bucket to open/close two weekends ago. Major bummer until I figured out what was wrong and did a temp fix with duct tape. /w3tcompact/icons/smile.gif NOT being able to use the 4n1 for a couple of hours was painful. Its so easy to take these things for granted. Then you don't have the use of an implement and it really hurts! /w3tcompact/icons/smile.gif
The 460 FEL including the 4n1 was about $4,600. I don't have a break down on what the 4n1 cost.
Later...
Dan
2009 Freightliner Columbia 120  10-Speed, Mercedes MBE4000, 6x4 (A52128)
2009 Freightliner...
Wolverine Quick Attach Power Rake (A50514)
Wolverine Quick...
(8) TRACTOR WEIGHTS (A51244)
(8) TRACTOR...
1999 Freightliner Service Truck (A50514)
1999 Freightliner...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
2015 CATERPILLAR 573C FELLER BUNCHER (A51242)
2015 CATERPILLAR...
