4 gang switch panel on 1533
   / 4 gang switch panel on 1533 #1
Bungiex88
Dysart
73 Farmall 574, 2016 mahindra 1533
Looking at putting extra led bar lights on my 1533. Was wondering if anyone has mounted a switch panel on a 1533 or 1538. Where's a good place to put it. Anyone have pictures where they put theres at
Wasn't sure if on the front dash or side fender somewhere just looking for ideas
   / 4 gang switch panel on 1533 #3
I have a 1538 but haven't added switches. From what I have done I'd be inclined to put them on the dash. Seems under the steering wheel/column would be a good spot. Tap a wire from the ignition switch, the battery and wire that into a relay. From there you can power almost all your current and future needs. The wire from the battery should have a fuse near the battery. The ignition wire you tap should be fused already but you should add a tiny 1-2amp fuse so if something happens on that side it just takes out the added switches and not the machine.
Logistically that lower plastic cover comes off easily so drilling some holes for the round style switches would be easy. The other option is a prefab type bracket that holds the switches.
My fear is the fender is subject to damage from both the top and bottom.
   / 4 gang switch panel on 1533 #4
There seems to be plenty of open space above the light switches on the dash. Just get your dremel tool and go to town since it's made of plastic. Cut rectangular openings and use snap in rocker switches or drill round holes and use toggle switches.
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2005 KENWORTH T300 (A52472)
2005 KENWORTH T300...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
