MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 57,354
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Well, since everyone was so helpful in this post about No Spark and we got it going, I have some more issues that I could use assistance with. It has an updraft carb. It is a Marvel Schebler. I took the air intake off so that I could see that the choke is operating correctly. It is. After I run it for a few minutes, the exhaust starts to belch smoke like the unit is running too rich. The fuel starts dripping out of the inlet of the carb, confirming, in my mind, at least, that there is more fuel than the engine can suck up. Where should I start looking for problems?
I've adjusted the idle adjusting needle screw to factory specs(one turn out) with no affect. Fuel keeps drippng out of the air inlet side of the carb. I'm guessing it has something to do with the needle and float system, but it's been a while since I've worked on carbs, especially an updraft. Any suggestions?
