4 cyl. diesel mitsubishi d1600
   / 4 cyl. diesel mitsubishi d1600 #1
TROUBLED
What oil grade to use for oil change and capacity with filter?
   / 4 cyl. diesel mitsubishi d1600 #2
15w40 will work fine. There are plenty of options though. You can run a 10w30 in colder climates. Some will suggest 5w40. Just make sure it's a diesel rated oil. ( C rated)
There are probably 1000 oil threads on TBN
Oil Capacity: not sure. Add three quarts and check the dipstick. Just add a little more until it's in the operating range. Start it up, wait for oil pressure to come up, check for leaks near filter, then shut it off. Check the dipstick, it might need a bit more oil once the new filter has been filled.
I'll bet it's going to hold between 4 and 6 qts. For a wager I would bet 4.75.
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2020 KUBOTA RTV...
2007 JLG 600S TELESCOPIC MANLIFT (A52705)
2007 JLG 600S...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
UNDERCARRIAGE ROLLERS (A53843)
UNDERCARRIAGE...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51692)
2014 International...
