3x20 tool box options
   / 3x20 tool box options #1
UnclePaul
Bronze Member
Unionville, Pa
Kubota L39, John Deere z950a, 1965' 110
I have the optional John Deere tool box and mounting bracket on the front of my cab on my 3720. This would be fine but the tool box is just cheep plastic with no seals. It leaks so bad that everything inside just rusts. Has any one found a good water proof box that will fit the JD holder? Thanks for the input in advance. UnclePaul
   / 3x20 tool box options #2
I had a 3720 cab and now have 4520 cab. The 4520 puts the tool box on front of the grill gaurd and it has enough clearance to miss the FEL. I don't think the 3720 has enough room. The 4520 is also metal and does a good job of keeping out water. I also had the plastic toolbox on my 3720. I drilled 2 small holes in the bottom corners to let any water out. Tools still tended to get rusty, so I oiled them occassionally.
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2013 UTILITY DRY VAN TRAILER (A54607)
2013 UTILITY DRY...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
BELSHE DT-235 (A53843)
