3x20 Series Owners: Do you have a switch to 'activate' your 3rd SCV?
   / 3x20 Series Owners: Do you have a switch to 'activate' your 3rd SCV? #1
kennyd
Advertiser
Westminster, MD
John Deere 3720 CAB/TLB, JD455
Well, if you do, and it's annoying as heck, then BoltOnHooks LLC has the solution!
This module eliminates the cumbersome 3rd SCV Switch found on the model year 2011 and newer 3x20 (3320 / 3520 / 3720) cabbed and open station machines with the electro/hydraulic 3rd rear SCV that is operated from the joystick handle.
This device simply plugs into the harness inside the console allowing you to completely remove the switch, that space can be now used for another switch, or our USB/USB-C Voltmeter accessory, or simply blanked off. Once installed, the 3rd SCV will be ready for use whenever the key is in the RUN position or the tractor is running without first needing to 'arm' or 'activate' the system with that rocker switch.
   / 3x20 Series Owners: Do you have a switch to 'activate' your 3rd SCV? #2
Looks like a simple solution to an annoyance. Do you know if it will work on the 4x20 series as well?
It should, but I have not tested that. Honestly I did not know the 4x20's had that system too. Best to contact me offline and we can talk it out.
info@boltonhooks.com
   / 3x20 Series Owners: Do you have a switch to 'activate' your 3rd SCV? #4
What was the purpose of that switch to begin with?
You'd have to ask the JD engineer that, LOL. No other machines have it.
Farmall 656 2WD Tractor (A49251)
Farmall 656 2WD...
2009 Ford Flex SUV (A46684)
2009 Ford Flex SUV...
2013 John Deere 544K Articulated Wheel Loader (A46683)
2013 John Deere...
Smooth Wall Ventilation Culverts (A47369)
Smooth Wall...
Brush Chief 5ft. Rotary Cutter (A49339)
Brush Chief 5ft...
Lockwood 14ft Even-Flow Box (A47369)
Lockwood 14ft...
