3x20 series Cruise question
   / 3x20 series Cruise question #1
orlo
Platinum Member
Guildhall, VT
JD 2305/JD 4720 cab
Hi:
I do plan on getting the automotive +/- control but I don't have it now.
My question is this. I noticed yesterday that the cruise switch has three positions: Off, On, and a momentary position on the ON side. Once I engage it if I press the momentary side the tractor will slow down an increment (was about .5mph yesterday). I actually like this feature since I use it to 'slow' down rather than just turning off the cruise which just about skids the rear wheels unless I can exactly match the pedal setting.
I thought it might be a 'coast', or 'reset' but it only slows down a little per push and doesn't seem to slow down more if you hold the button (I need to experiment more...)
I can't find this documented anywhere. Does anyone know if this is an 'official' feature of it it's just some odd behavior that's with the cruise.
Thanks,
   / 3x20 series Cruise question #2
When you get the automotive cruise upgrade kit you will see that the new switch has cruise "set" and the "-" or slow down symbol in the same position. That tells me the same input to the computer on the tractor does both functions. Therefore you already have a "limited free preview" of automotive cruise on board already.
   / 3x20 series Cruise question #3
Wow. Can't believe I never noticed that.
Thanks for the tip guys! :)
(1) 16ft Tarter Gate (A48837)
(1) 16ft Tarter...
2014 Ford F-150 Crew Cab Pickup Truck (A48081)
2014 Ford F-150...
PALLET OF ARMSTRONG TILE FLOORING (A50460)
PALLET OF...
2021 KUBOTA SVL97-2 SKID STEER (A50458)
2021 KUBOTA...
(INOP) SAKAI SV540 PADFOOT COMPACTOR (A50458)
(INOP) SAKAI SV540...
2000 Volvo VNL Truck, VIN # 4V4N21JF7YN250203 (A48836)
2000 Volvo VNL...
