3rd valve hydraulic control
   / 3rd valve hydraulic control #1
Bradbilt
Gilbert PA
Ford 260C, Ford 8N, NewHolland GT22,
I just purchased a Ford 260C Industrial tractor and it has a 744 Loader on it
It has a outlet in the back(and yes I CAN use it, but don't want to)
I would like to some how plumb a 3rd valve to the bucket for my newly purchased grapple bucket and future power angle snow plow.
Now here is where I am in over my head....
I would like to control that 3ed valve with a "switch". Whether a push button, roller or toggle. And also mount it on the loader joystick so it is more user friendly than the 3rd valve under the seat
I guess what I am looking for is switch kinda like a pilot control on a skid steer.
Any ideas or suggestions?
   / 3rd valve hydraulic control #2
Any suggestions for a switch?
   / 3rd valve hydraulic control #4
I would use a water proof switch in a factory handle or make your own.
A boat place would have the switches.
I found this made by Scorpion
X series
Scorpion Technologies LTD. - X-Series
My current joystick has a "disconnect" switch already to disengage the transmission, so you can throttle up to move the loader faster but not move the machine.
I figured the trigger would be perfect for that and the push buttons could control the 3rd valve
Good idea?
   / 3rd valve hydraulic control #7
Do you have a PB line or a hyd block?
If so, add your solenoid valve in series with the PB flow.
I don't know. How can I find that out?
   / 3rd valve hydraulic control #9
If you don't have a manual, then you have to start with the pump and follow the hoses and draw out what you have.
Anyway, if you have external hoses from the pump, you can add valves in series with the hyd flow.
Ok, thanks. I wasn't sure if I could add another block in the loader controls and control it with electric solenoids
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
2007 CHEVROLET C7500 BUCKET TRUCK (A51406)
2007 CHEVROLET...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
2007 Ford Focus Hatchback (A55853)
2007 Ford Focus...
