3rd function valve failed wr long
   / 3rd function valve failed wr long #1
Bfitzgerald3
Bronze Member
Harbor springs, mich
Kubota Mx5100
Three days ago, everything worked perfectly. Yesterday, disconnected the grapple run by the valve, used the bucket for awhile, reattached the grapple, and blew a fuse when I tried to open the jaws. The jaws lifted about two inches. Replaced the fuse, ran through a dozen or so open/close cycles and all seemed happy. Then it farted out again.
Hoping a wire wore through and shorted things, I inspected the wires... No problems. I'm assuming the problem is somewhere in the valve and am hoping there is an easy fix. Any advice out there? Am I looking at a valve replacement?
Thanks!
   / 3rd function valve failed wr long #2
You can check the valve for good spool operation.
You should be able to get a new solenoid from the dealer.
You might have a manual way to test the valve. Look on the end of the solenoid and see if there is a plunger you can push to test the spool operation.
Measure the coil resistance and see if it is correct. Compare it to the other solenoid.
2012 Jaguar XJ Sedan (A55758)
2012 Jaguar XJ...
2007 Volvo VNL Truck Tractor (A55218)
2007 Volvo VNL...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
2011 Nissan Maxima Sedan (A55758)
2011 Nissan Maxima...
Advance SC750 28in Floor Scrubber (A55787)
Advance SC750 28in...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
