3rd Function Solenoid Valve Help
   / 3rd Function Solenoid Valve Help #1
Captain Dirty
Platinum Member
Eastern Mass
Goldoni 600, Kubota L45
After attaching the snowblade to the FEL of my L45 with dealer-installed 3rd function valve, pressing the "A" button moved the blade left, pressing the "B" button nothing. I switched the hoses; A moved the blade R, B-nothing. Shut off the engine but left the ignition on; A produced a clunk that I took to be the solenoid, B nothing. Obviously there is a problem in the 3rd function solenoid valve.
Electrically, a latched relay "arms" the A and B buttons. Pressing a button activates a relay that sends current to the corresponding coil. Mechanically the energized coil moves an armature in a tube. The armature moves a pin that moves the spool to direct the hydraulic fluid. The spool is centered in an open center position by two springs that return the spool to neutral when the coil is not energized.
The connectors to the coils are 2-wire. The power wires to each coil show 14V and 0 V when the corresponding A or B button is pressed or released. The ground wires to each coil show continuity with the tractor chassis. Each coil shows 0 ohms on the 100-ohm scale. I think that is normal as I swapped the coils with the same results, A works, B does not. I also (perhaps unnecessarily) swapped the relays--same results.
Early on I rapped the solenoids with a mallet to no effect. Each tube has a pin on the end that manually pushes the armature. I cannot depress the A side. When I depress the B side, the spool moves and the plow angles, albeit slowly.
When I bought the tractor some years ago I followed conventional wisdom that getting a 3rd function at time of purchase was a better move than adding it later, but the function remained unused till now. Based upon my findings, I believe that the manual pin on the A side is frozen but the armature moves, and the armature on the B side is stuck so that the force of the manual pin will overcome the stiction while the force of the coil field will not.
Have I overlooked something I can try to get the valve working? Replacing the valve will be a hassle I do not want to attempt in Winter. I can manually angle the plow in the B direction by dismounting and pressing the manual override pin. TIA
   / 3rd Function Solenoid Valve Help #2
Plunger is probably stuck in the B solenoid from not being used. Might have to take it apart to free it up.
Update
My troubleshooting eliminated all faults, but the function still did not work. I started over.
Eventually I found a bundle of wires had been crushed and one wire kinked and severed. Perhaps the crushing had held the conductor together enough to get voltage the first time, and subsequent manipulation of the wiring harness had opened the "open". A crimped butt splice and some heat shrink tubing effected the repair.
I now have an operational 3rd function switch and a detailed understanding of how it works. As airbiscuit said in one of my earlier posts, "It's beer time." Given the season, I think a triple would be more appropriate than a PBR
2020 KUBOTA RTV...
90018 (A48082)
90018 (A48082)
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
20 ft. Shipping Container (A50860)
20 ft. Shipping...
2022 Kawasaki Z125 Pro Motorcycle (A48082)
2022 Kawasaki Z125...
2015 Ford Taurus Sedan (A48082)
2015 Ford Taurus...
