3rd Function, headlights and horn.
   / 3rd Function, headlights and horn. #1
BufordBoone
Platinum Member
Tuscaloosa, Al
Kubota L5740 & M7060
Kubota M7060 with a cab.
Today I noticed my 3rd function button wouldn't light up. Also wouldn't work. I figured it to be a fuse.
Searching, I can't find any fuse blown. I looked at every one in the fuse box under the steering wheel.
In checking other electrical things, I discovered the horn doesn't sound and the lights (on the hood) don't work.
Tail lights, hazards, turn signals, cab front and back, all work fine.
Since the button isn't even illuminated, I'm still guessing it is not getting power.
Any ideas? Thanks!
   / 3rd Function, headlights and horn. #2
Start at lamps the are not lit up and trace back to power source, a broken wire or corroded connection will do you in...
CASE DAVID BROWN 990 TRACTOR (A50459)
CASE DAVID BROWN...
1980 CATERPILLAR 120G MOTORGRADER (A50458)
1980 CATERPILLAR...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2018 RoGator 1100C (A50397)
2018 RoGator 1100C...
Earthquake Tiller (A48837)
Earthquake Tiller...
GM Coach Bus (A50860)
