3ptn won't lift
   / 3ptn won't lift #1
2515R Dude
Platinum Member
KY
Branson 2515R
Should tell first, the hydraulic oil on the Max mark, the flow control valve is completely opened. Checked both those easy solutions first :)
The tractor in Branson 2515R shuffle shift.
Was working today spreading gravel on my driveway with the box blade. The 3 point suddenly stopped lifting. All other hydraulics seem to work, however the load control valve makes some buzzing/sipping sound and hot to the touch.
Any thoughts?
   / 3ptn won't lift #2
Check the remotes levers. Make sure those are in the neutral position.
Also, if you have a backhoe and it uses a loop instead of the remotes, make sure those hoses are fully connected.
   / 3ptn won't lift
Holy Moly.... you saved my bacon again, i feel so embarrassed....
Yes, the remote lever stuck and i did not see it.
I was 2 mm away from tearing the loader control down....
   / 3ptn won't lift #4
Yup, 11 times out of 10, that's usually the issue.
The noise and heat on the loader valve was the fluid being forced through the relief valve at full pressure and possible at full flow depending on the engine RPM. This is called dead heading the hydraulic pump which is very hard on them due to all the heat it produces.
   / 3ptn won't lift
Yes, it is what i thought, but could not figure the problem, so, as you very delicately and correctly stated, 11 times out of 10 the problem is in the container between the operator's ears
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
(2) SQUIRREL CAGE FANS (A54757)
(2) SQUIRREL CAGE...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2004 Volvo XC90 VAN (A55853)
2004 Volvo XC90...
