3pt wont move and tractor wont run without loader attached
   / 3pt wont move and tractor wont run without loader attached #1
Austin6132
Farm pro 2425
I own a farm pro 2425 y385 the rear 3 pt wont lift and when I detached the loader hydraulics it completely stalled out and now it wont start without the loader hydraulics connected idk how this thing works I work on tractors for a livening but I’m lost. any suggestions or anything that could possibly be wrong with it? Not leaking fluid or anything
   / 3pt wont move and tractor wont run without loader attached #2
:rolleyes:
   / 3pt wont move and tractor wont run without loader attached #3
Remote hydraulics in neutral position ?
   / 3pt wont move and tractor wont run without loader attached #4
How many lines do you have to disconnect when removing the loader? 3 or 4? If 3, then two of those will need to be connected back together.
So don't insist on starting the tractor like that, or you'll damage the hydraulic pump.
   / 3pt wont move and tractor wont run without loader attached #5
So insist on starting the tractor like that, or you'll damage the hydraulic pump.
^^^This
Basically when removing the loader, does the valve stay connected to the tractor?
Or does the loader valve go with the disconnected loader frame?
IF the valve goes with the loader frame, the P and PB hoses will need reconnected for the 3PH to work and not deadhead the pump.
The
there’s only 2 hoses a pressure and return
   / 3pt wont move and tractor wont run without loader attached #8
Connect them or like posted the pump will be damaged.
   / 3pt wont move and tractor wont run without loader attached #9
Ok, so those two hoses must be connected to each other.
I found a manual for a Jinma 254, which I believe is very similar to the Farm Pro 2425. There is a section where it explains the front loader and how the hoses must be connected. Hopefully it helps you understanding a bit better. Just scroll down to page 20: https://www.kenotractors.com/wp-content/uploads/2017/09/JINMA200Series-2016.pdf
   / 3pt wont move and tractor wont run without loader attached #10
Need a loop back hose to connect the two connectors to each other otherwise hydraulic pump is deadheading against the blockage cause by quick connect... If you continue trying to run tractor with out loop back hose it will possibly destroy the pump....
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
2018 New Holland TS6.120 4WD 96HP Agricultural Tractor (A50322)
2018 New Holland...
Harlo HP8500 Forklift (RIDE AND DRIVE) (A50774)
Harlo HP8500...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
