3pt won't lower - duhhh issue
   / 3pt won't lower - duhhh issue #1
CMV
Platinum Member
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
So Thought I broke something....3 pt arms would go up, but not come back down. Draft control all the way down, move handle back and forth, just up, up, up, no downward movement. Tried rear handle and watched linkage - what I could see looked fine.
So after tinkering for a while and now 3pt arms as high as they'd go, had a real dilemma - how do I get the bush hog off? Raised all the way, as soon as hyd toplink leaked down that would put weight on the PTO shaft and try to bend it. Also couldn't extend toplink enough to not hit bush hog frame risking bending it to have enough room to disconnect from PTO spline on tractor. So bush hog in the air, no way to lower it, no way to disconnect it.....hmmmmm...I'm in trouble......
So just before giving up and blocking it up so it couldn't change angle and damage shaft I thought to try the knob under seat for speed adjustment. I have never touched that and no idea why after tinkering around so long it crossed my mind. But sure enough, about 1/4 turn and 3pt lowered as normal.
Felt dumb and relieved at same time :) So moral of story.....if 3pt goes up but won't come back down, check that knob. Apparently mine must vibrate itself clockwise or I unknowingly bump it with my foot and turn it some. Because I'm sure I've never intentionally adjusted it.
   / 3pt won't lower - duhhh issue #2
I must kick that knob all the time because I have to reach down to adjust it often.
   / 3pt won't lower - duhhh issue #3
It's not so much a "duhhh issue" as a learning experience.
And good on'ya for posting about it. :thumbsup:
   / 3pt won't lower - duhhh issue #5
I think we would ALL be surprised if we really knew how many have had the EXACT same experience as you - - CMV.
Deere 317G (A50120)
Deere 317G (A50120)
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2013 Mercedes-Benz C-Class C250 Sedan (A50324)
2013 Mercedes-Benz...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
