3-Point Hitch 3pt whining sound???
   / 3pt whining sound??? #1
jmt1271
Platinum Member
MO
Kubota L2501
My 06 3520 is my first tractor so sometimes I am unsure whether things are "right". When I raise my 3 pt all the way up, with or without implement, it periodically lowers a very small amount and then goes back up. It makes a whining sound the whole time this happens. It occurs about once a minute, usually, the whole time the 3 pt is raised. Its as if it is bleeding down and then correcting. Is this a problem?
   / 3pt whining sound??? #2
Nah, that ain't right... Sounds like the sensor that reads the position of the 3pt arms and shuts the pump off is out of adjustment. Or failing.
That could be dangerous ---
Does it continuously drop and then raise the entire time you are operating the tractor? Or just randomly occurs?
If so, when you're trying to attach or detach a piece of equipment, would you have to "guess" when it's gonna act up?
Dealer needs to check it out --- especially if it's still under warranty.
AKfish
It is less than a yr old and has done this since new. It is not as bad as you are thinking. It only does it(as far as I can tell) when its raised fully. It never drops more than an inch or so, and immediately goes back up. it isnt an issue when I am using an implement. I will give the dealer a call and see what we need to do.
   / 3pt whining sound??? #4
It is definitely not right, I know the older tractors had a mechanical adjustment for this, not sure how it's done on the new series though...but get your dealer to fix it under the warranty.
   / 3pt whining sound??? #5
Seems like you should contact your dealer, and get that checked out.
I will contact the dealer tomorrow and see. Thanks.
2018 Bobcat T590 (A50120)
2018 Bobcat T590...
2016 Ford Explorer...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A50323)
2015 International...
2000 Gallon Fuel Tank W/Pump (A50774)
2000 Gallon Fuel...
