3pt weight capacity??
   / 3pt weight capacity?? #1
emery
Western Mass
Kubota b9200
My Kubota B9200 lists 550 lbs for a max 3pt implement weight. I want to try a 5' tiller that weights 650 but am afraid of doing damage.
Can you tell me if I would in fact risk damage or will the hitch just refuse to lift that much weight???
This tractor novice would be thankful for any advice.
   / 3pt weight capacity?? #2
You sure thats all that tractor is rated to lift? Seem a bit low. I have a TC21D and if im not mistaken its rated at 1265 lift Your tractor is all of the TC21D isint it
I'm not sure what a TC21D is, but I got the 550 lb specs out of my manual. the B9200 is 23hp 4 cylinder diesel
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2020 CASE 580N EP BACKHOE (A51246)
2020 CASE 580N EP...
UNUSED CFG INDUSTRIAL M-DRG MINI DIGGER (A51248)
UNUSED CFG...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
JOHN DEERE 1050 TRACTOR (A51247)
JOHN DEERE 1050...
PALLET OF NEW HOLLAND PARTS (A51248)
PALLET OF NEW...
