3pt sway bars
   / 3pt sway bars #1
Anonymous Poster
Epic Contributor
My 1720 has outer 3pt sway bars. Turnbuckles really. Unfortunately, I have a couple 3pt pieces that clamp over the 3pt arms right where these turnbuckle bolts attach to the 3pt arm. I would like to find some sway bars that attach to the hole closer in towards the tractor, 2" shorter. Any available?
I was just going to replace the one end of the turnbuckle with a shorter piece - but they turn out to be 14mm metric threads, left-handed, and this turns out to be difficult to find!
Guess I'll have to start fabricating if I can't find anything on the shelf. Could have been easy, but never is...
--->Paul
   / 3pt sway bars #2
Go to Mcmaster Carr Search for 98817A280. 14 MM left hand threaded rod $14.76 each.
Don't know what you need on the end for a fitting.
Why not just cut the existing piece down? Or order a spare part from New Holland & cut that down if you want to maintain the originals.
If you've got a picture or sketch of the setup, we can provide more help.
Good luck.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
Skid Steer Plate Attachment (A50322)
Skid Steer Plate...
Mini Excavator Attachment Set (A50121)
Mini Excavator...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
