Spreader 3pt Spreaders
   / 3pt Spreaders #1
kevincook
Platinum Member
k
Hello everyone,
I was looking for a Landpride 3pt spreader the other day and one of the dealers I talked to gave me a brochure for a Sitrex spreader made in Italy. I have done a little digging and it looks to me like the Sitrex spreader is exactly the same as the Landpride spreader. At first I wasn't interested because I wasn't familiar with the name but if Landpride is buying their spreaders from Sitrex I think I may buy one since the price is about $100 less than the Landpride.
Any thoughts?
http://www.landpride.com/lp/products/fs_specs.html
   / 3pt Spreaders #2
I'd say it depends on what you're planning on spreading. The Italians make first class equipment. Either would probably work fine with fertilizer or seed. Lime will be a hassle. Lime will sometimes bridge and stop flowing with a conical hopper design.
   / 3pt Spreaders #3
Kevin,I just ordered a Landpride FS500 today.You are right when you say they all (brands) look alike.I also think the bulk of these spreaders are all made by one company and painted many different colors.
   / 3pt Spreaders #4
Those two spreaders are probably very close in the way they are made. Most spreaders just have one basic design. There are some with more frills, but if you're wanting to broadcast a product, I'd go with whichever one is cheaper.
   / 3pt Spreaders #5
I brought a spreader from Fleet Farm 5 yrs ago for $300 that looks the same, even that crooked stirrer with the wheel on it. The only difference are the controls are on the right side. The gear box has a grease zerk on it to fill it with gun grease instead of gear grease.
One serious problem I had was running the PTO without having the little doors open that allow fertilizer to flow out. The fertilizer got hot and solidified, tearing up the flush tab stirrer at the bottom. I had to hand broadcast ~600 lbs of fertilizer and break up the neo-lithic formation with a sledge hammer that formed in the bottom. That crookedy central stirrer with the wheel survived. I spent $55 with my local welder repairing it since I couldn't find parts
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
HOMEADE PIN ON 2 PRONG HAY SPEAR (A51247)
HOMEADE PIN ON 2...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51691)
2001 Dodge Ram...
IRONCRAFT 84" ROTARY MOWER (A51247)
IRONCRAFT 84"...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
