Quick Hitches 3pt Spreader on Quick Hitch?
   / 3pt Spreader on Quick Hitch? #1
kdlklm
Saskatchewan, Canada
Kubota BX1830
Is anyone using a fertilizer spreader on a quick hitch. If so what make and model's. Any photos would be great to.
   / 3pt Spreader on Quick Hitch? #2
Our quick hitch should work great for you. We can make them to fit ANY size tractor. You can see the full product line at carterandsonsllc.com
   / 3pt Spreader on Quick Hitch? #3
I have adapted an atv electric spreader to my imatch system. It works great for smaller food plots(less than 4 acres). It has the benefit of being able to spread the very small seeds like rape. I love the quickhith for fast changes,
   / 3pt Spreader on Quick Hitch? #4
Am posting from my laptop on the road right now, so no photos. But I have a PTO driven three point hitch seeder/spreader (cone style) that works just fine with Pat's Easy Hitch system. But I was lucky that I had plenty of extension left in the spreader's PTO drive shaft. This is important, because when you add most QuickHitch designs, they move the implement 3-4" away from the tractor. That then necessarily requires an equal extension of the PTO driveline.
//greg//
   / 3pt Spreader on Quick Hitch? #5
//greg//
This is the great thing about our design, the quick hitch mounts directly over the existing draw pin bearing so there is no need for an extension on either the PTO shaft or the top link. You also maintain all of your lifting capacity, whereas with the other designs you loose lifting capacity.
   / 3pt Spreader on Quick Hitch? #6
Don't get me wrong, I've got no reason to criticize you or your product. But assuming your avatar is your hitch - I can't buy that claim. The device in that photo appears to attach directly to where an implement lift pin would normally reside. So what I see mounts the implement behind its normal attachment point - just like all the others that use the swivel ball to mate the product with the lift arm. As such, a proportionate extension of both PTO shaft and toplink must be expected.
//greg//
   / 3pt Spreader on Quick Hitch? #7
My Cosmo 500 spreader is not quick hitch compatible, but it has not been that big of deal taking off the imatch and hooking up the spreader. The spreader is not very heavy.
   / 3pt Spreader on Quick Hitch? #8
//greg//
Looks like the one in the avitar puts the hook ABOVE them normal attach point instead of behind. So, you may not have to add length, you will loose some functionality of your lift, your ground engaging attachments will loose a couple inches of depth.
There is just no way to add a quick attach of any sort to the factory lift arms and NOT alter some aspect of the lift. It is physically impossible. The only way to get quick attach hooks and not change any aspect of the hitch would be to cut the ends off the arms and place the hook so that it is in the same place the original eye was.
   / 3pt Spreader on Quick Hitch? #9
I doubt it, more likely they were set on end for the photo. EZ can confirm or deny
//greg//
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2012 Porsche Panamera Hatchback (A50324)
2012 Porsche...
John Deere Hayrack (A50515)
John Deere Hayrack...
2013 John Deere 824K (A52128)
2013 John Deere...
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
