3pt splitter
/ 3pt splitter #1
Varmintmist
Platinum Member
Chicora, PA
Mahindra3510
Anyone here have experiance with the 3 point logsplitter from Northern Tool?
The price is right and it would be shared within the family. I just wonder how well they work.
/ 3pt splitter #2
Do you have an auxiliary remote?
If so, how many GPMs to they put out?
My brother has one, but it runs off the back of a 50 HP farm tractor. In this case, it works great.
You could also add a PTO pump if the tractor is small.
/ 3pt splitter
The main tractor it would be used on would be a JD950 27 eng hp, with the aux remotes. It might be put on a Mahindra 3510, but most likely just the 950. The 950 runs a hoe fine so I figure there is enough gpm
/ 3pt splitter #5
Your tractor will likely have enough GPM but not the PSI needed for splitting some real snarly wood.
/ 3pt splitter #6
I have one that I build it to work with JD 850, and now is power by Mahindra 2015 tractor. I does fine for the most part. I'm splitting a red oak that same of it is still green, it does have fair amount of knots. I'm running mostly at the idle speed. The cylinder size is 2.75" dia, stroke 24" /forums/images/graemlins/cool.gif
/ 3pt splitter #7
Jut got 3 of them need to sell 1 of them will get you a photo see what you think. I have a Kubota L4610 9.6 gal. per min. works good, also got the 4 way wege makes 4 out of 1 way better!!!
Rich
/ 3pt splitter #8
Varmintmist,
</font><font color="blue" class="small">( Anyone here have experiance with the 3 point logsplitter from Northern Tool?)</font>
I bought one this summer - the horizontal model. I run it with a John Deere 4300 - 9 gpm. I don't think that I'd be happy with a whole lot less flow.
The slide needed to be smoothed up a bit. The flame cut pieces between the top and the bottom of the slide started galling the beam on one side. A few minutes with a die grinder solved the problem.
The paint isn't the best. It is coming off in a couple of places. Looks like poor surface prep.
I've only split five or six cords so far so I really don't know how it will hold up long term. Seems to be built sturdy enough for a four inch cylinder. I haven't yet tried a big white oak top or gum, so I don't what it will do under extreme stress/twist.
New Holland T5 120 Tractor (A64047)
New Holland T5 120...
2017 Ford Explorer SUV (A61569)
2017 Ford Explorer...
Great Dane Van Trailer 1989 (A63118)
Great Dane Van...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
International 9200 (A63118)
International 9200...
