Snowblower 3pt snowblower woes
   / 3pt snowblower woes #1
emery
Western Mass
Kubota b9200
Eager as a beaver I went out to try using 3pt snowblower and it just kept clogging. I had rpms up to 2000 but it just would not work. Mostly it acted like a plow and just pushed a clump of snow instead of drawing it into augers.
Is this normal for for the kinda 'sticky' snow we had? The blower's a Woods so I would think it has a time tested design.
I actally thought I might enjoy a storm or two with the new equipment, but I sure am dissapointed!
   / 3pt snowblower woes #2
This is normal with sticky snow, having new paint makes it worse. If it is just the chute that plugs clean good and spray with none stick cooking oil.
   / 3pt snowblower woes #3
I waxed the entire inside of my 54" Agrotrend snowblower with "Gulf Candle Making Wax". Just rub the wax block on the paint on a relatively warm day (50-60 degrees). This was two years ago, and most of the wax is still visible...except in the chute..... really works good in all snow conditions.
   / 3pt snowblower woes #4
I was going to start a similar thread. I was going to use my Ford 715A 3pt snowblower yesterday for the first time. The shear pin is a 1/4" diameter bolt. Everytime I started pushing in the snow, the shearpin broke. I tried it 4 times! The snow was pretty light, and I wasn't getting rocks stuck in the beaters. How do I fix this? I never used it before, but I bought the blower with my tractor last March, and I went first looked at the tractor, the blower was on it, and the seller was using it, so I know it worked then.
Thanks for any suggestions!
Rich
   / 3pt snowblower woes #5
Richie...
Is it a Grade 2 bolt that's on it now... shearing...?
Try a Grade 5 bolt, but watch it closely... perhaps you may have another issue with the blower... a stick or debris lodged maybe you can't see....?
Hey... that was fun unloading that 3 bottom plow off my truck in the slippery snow mini-storm... /w3tcompact/icons/wink.gif
   / 3pt snowblower woes #6
Assuming that the guy was using it with those actual shear bolts, make sure that:
(a) everything's greased up okay, or
(b) that the impeller and/or auger is not rubbing against the housing. I had a stone bend one of my blades last year just enough so that it was banging against the housing. Whacked it with a hammer a few times to bend it back.
(c) If everything's greased okay and spins freely without any rubbing, just change the shear bolts. Get bolts rated #2.
   / 3pt snowblower woes #7
Thanks, John! Yeah they were grade 2, and I thought of upgrading, but I was afraid that if something was wrong and I put in a grade 5, I might damage something if they didn't shear. I thought there must be some reason why they're breaking. If you think it's safe I'll try grade 5. Just a little trip to Carl Trinkle's for some more bolts.
I was thinking of you Saturday night, after the auction. You didn't believe me when I said we were in for some snow, and I was wondering if you had trouble getting the plow off your truck. It would have been easier if you had forks on your bucket. Oh, wait, you didn't buy those, did you? (I know, I know, they had to be modified, just busting your chops./w3tcompact/icons/smile.gif)
Rich
   / 3pt snowblower woes #9
Hi Rich,
If you purchased that locally, call the ex-owner and ask if he changed/lowered "grades" at the last minute {quick substitution}
If the unit has been working fine the last 10 years using Grade 2 bolts, then something is obviously wrong, and I don't want you to compound the problem with grade 5...{especially at my suggestion /w3tcompact/icons/blush.gif}...
I as a rule would not go UP from Grade 2>5 {with the exception of a rotary cutter/driveline on a 50+ PTO hp tractor & the gearbox was rated accordingly} (and actually now I would spend $100+ for a slip clutch instead /w3tcompact/icons/wink.gif)
   / 3pt snowblower woes #10
Thanks, John. The guy I bought it from has moved to North Carolina. As luck would have it, my local tractor repair guy, who fixed my three point hitch is coming over to make some adjustments on it. I asked him to take a look at the snowblower to see if he could see the problem. I'll post it when I find out, for everyone's info, in case it's something that would be helpful to all.
Rich
2014 BMW X3 (A50324)
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
UNUSED 2025 INDUSTRIAS AMERICA 7014 DUMP TRL (A51243)
UNUSED 2025...
2013 TIGERCAT 720E WHEEL FELLER BUNCHER (A51242)
2013 TIGERCAT 720E...
2018 WOOD MAXX TM 86H WOOD CHIPPER (A51243)
2018 WOOD MAXX TM...
