Chipper 3pt/pto chipper shredder question
/ 3pt/pto chipper shredder question #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
For those who have 3pt mounted chippers, will they operate as a shredder for small material, leaves ect?
I have a 5hp Bearcat chipper/shredder. It works well, but is underpowered and physically small for a lot of my stuff now.
/ 3pt/pto chipper shredder question #2
My understanding is that 3ph "chippers" do not do a good job on soft vegetation like leaves, because they don't have the "flail" blades that chipper/shredders have.
I have a "Wood Pro AVP" (the "AVP" stands for "all vegetation processor") pto-driven chipper/shredder. In addition to the chipping blades, it has flail blades as well, and does a pretty good job of grinding stuff up. BTW, this machine requires that your tractor have at least 22 pto hp.
Here's a link to the mfr's web page:
WOODPRO AVP
Hope this helps.
Ah... I have 16hp on the pto of my mid-80's Kubota B8200. That would put that model out of the running for me...
I would want one with the extra hammers or knives. I guess my Bearcat would be a hybrid, since it has the chipper, but it is the front of the drum. The back of the drum has flail knives in it. I am really surpassing what the machine can do though.
/ 3pt/pto chipper shredder question #5
For best shredding, get a combo machine. I have this one (pic). It is a WW grinder. The company is no longer in business. My 14 PTO HP can handle up to 3" branches - although dry hardwood seems to wear the blades pretty fast.
/ 3pt/pto chipper shredder question #6
Woods Equipment makes a pretty good chipper shredder for 3pt that my dealer showed me recently. We were not nearly as impressed with the chipping as we were with the shredding. Drop in some brushy brush, thick or thin and in the blink-of-an-eye, it's dust. The dealer ran it on a Kioti CK20 just like mine and it handled it just fine with 15.5 PTO HP.
Here's a link to their page on this 5" model.
Woods Chipper/Shredder 5000
John
/ 3pt/pto chipper shredder question #8
</font><font color="blue" class="small">( The Woods is a Bear Cat. I have the 20 HP model.
It does a great job of shredding along with chipping. )</font>
If they are, they don't look anything like the Woods 5000 I posted about. The 5000 is a manual feed also, and the listed Bearcats are self feed.
John
/ 3pt/pto chipper shredder question #9
When I bought my Woods 5000 there was an identical Bearcat model.
/ 3pt/pto chipper shredder question #10
</font><font color="blue" class="small">( When I bought my Woods 5000 there was an identical Bearcat model. )</font>
Maybe they discontinued it. I know lots of equipment is made by the same OEM guys and rebadged.
The chipping on the 5000 left a lot to be desired in my opinion, but that shredder! John
/ 3pt/pto chipper shredder question #11
John
They are the same units.
Self feed means you feeding it. /forums/images/graemlins/grin.gif
/ 3pt/pto chipper shredder question #12
</font><font color="blue" class="small">( John
Self feed means you feeding it. )</font>
Oh, okay /forums/images/graemlins/crazy.gif
But that doesn't change the fact that the pics are VERY different machines. Maybe they have the picture on somewhere else and I'm missing it. You say you have the 20 HP model. That's a gas unit, not PTO? John
/ 3pt/pto chipper shredder question #13
</font><font color="blue" class="small">( My understanding is that 3ph "chippers" do not do a good job on soft vegetation like leaves, because they don't have the "flail" blades that chipper/shredders have.
)</font>
I currently have a Valby CH260 (w/ hydraulic feed) which is definately a chipper. It makes no pretences about being a shredder. Before that I had a Valby CH150.
In either case it shreads great if you fill the hopper with leaves, small branches etc. and then put in a tree or medium branch with leaves or branches all the stuff gets pulled into the disk and shredded well. Personally I think the Valby is a much heavier duty chipper than the Bearcat. I evaluated both I purchased and liked the Valby much better.Valby Chippers Andy
/ 3pt/pto chipper shredder question #14
Mistake on my part....
Valby does say their chippers can shread. "Shredding Paper Both ends of the knife are covered, so twigs or other material do not get hung up on the knives. This enables the chipper to also be used for shredding paper. " Shredding
Andy
/ 3pt/pto chipper shredder question #15
I think this must be the picture you are looking for. PTO Driven CS
The actual chipper/shredder unit is the same whether PTO driven or engine driven.
JackIL
/ 3pt/pto chipper shredder question #16
I agree w/ Andy. The big Valby was one of the other units I looked at. I think, from comparing specs, that the Valby and Vandermolen Wood Pro AVP are both beefier and more versatile units than the BearCats, although I think that both were more expensive when I got quotes on them.
Another consideration is machine safety. I think that chipper/shredders are, along with tillers and PHDs, just about the most dangerous tractor attachments that CUT owners use, because of the danger and possibly fatal consequences of coming into contact with their rapidly moving parts. One of the things that I liked about the Wood Pro was that its hopper is not horizontal and you feed in from above, angling the branches downward. The lip of the hopper is about 4' high and so deep that it is amost impossible to accidentally get your hands anywhere near the blades and flywheel.
That is particularly important becasue the flywheel and blade assembly has got to weigh well over 150# (30" diam and almost 5" thick). The Wood Pro can handle branches up to 6" diam and the power transfer system has it spinning at well over 2000 rpm when the rear pto is at 540 rpm. When you disengage the pto, its momentum is so great that it takes over 3 minutes to spin down. Because the motion of the knives tends to draw material in, anybody who comes in contact with it is going to be sliced, diced and pureed long before the machine stops. I feel a lot better knowing that the machine's design makes it almost impossible for me (or any other operator) to get in harm's way, even through stupidity or carelessness.
/ 3pt/pto chipper shredder question #17
</font><font color="blueclass=small">( I think this must be the picture you are looking for )</font>
Yes, thanks, that one looks like the Woods. I've been so busy, I probably was not looking carefully enough. This darn cold virus isn't helping concentration any either! Thanks again, John
EDIT: as to MadDog's post about safety issues, I notice that the shredder portion of the Woods/Bearcat is very easily accessed and the blades shredder blades are just below the surface of the "brushy" material covering them. An accident waiting to happen. When my dealer and I were demo'ing it, we were careful to throw the stuff in from a little distance. Those pulverizers are MEAN! John
2021 Redirective Crash Cushion Guardrail (A61568)
2021 Redirective...
2022 Jeep Grand Cherokee 4x4 SUV (A61569)
2022 Jeep Grand...
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
New/Unused AGT Industrial Gas-Powered Air Compressor (A61166)
New/Unused AGT...
New/Unused 20ft Metal Farm Driveway Gate (A61166)
New/Unused 20ft...
2019 Kubota MX5800 HST Tractor (A61166)
2019 Kubota MX5800...
