3pt problems on a M-4700?
/ 3pt problems on a M-4700? #1
tnpete
Adamsville Tn
14 in all but last one is a Kubota M4700 bought new. and still in great shape. But may be for sale next spring and b e replaced with a L48 TLB or a M59 TLB
I have a Kubota M-4700, And if I lift the 3pt all the way up. It feeds back into the loader hoses. AS in you can see the hoses swelling up from the pressure. The loader is plumbed using the power beyond on the tractor. I bought the tractor and loader new. And it just started it this year.
If I only lift what ever is on the 3pt arms until the loader hoses start swelling. and then bump the lever down just a bit. IT kicks the pump out and all is well. Anyone have any ideals?
Fluids and both filters were changed out so its not that.
Pete
/ 3pt problems on a M-4700? #2
The 3-point hitch lever travel needs to be re-adjusted so the flow shuts off in the top position. One easy fix is to put a stop on the touch lever slot to limit how far up it goes. The stop will be almost at the top of travel but not quite. You'll still have full hitch arm upward travel. There is a way to adjust the lever linkage but I don't have the details for the M4700 - maybe someone else will chime in. But the up-stop method for the lever is quick and effective.
Thanks that is what I have been doing. I have the stop set. and when it touches it. I just bump it back down a hair. and all it well. But would like to get it adjusted where that is not an issue. As I have others running it at times. And they do not watch what there doing.
Hope someone can help out on the adjustment. If not I will have to load it up and haul it an hour to the dealer. Then $100 to do something that will more then likely take them 10 minutes.
Pete
/ 3pt problems on a M-4700? #4
Pete, I had a look at a M4700 parts book - the 3-point hitch control valve and feedback linkage setup is different depending on your serial number. I would recommend spending the bucks on a Kubota M4700 Work Shop Manual for your specific rig. Might pay for itself in avoided hauls to the dealer.
Thanks a lot I guess I need to find a place to order the shop manual. And get it fixed.
Where is the best place to order one?
Pete
/ 3pt problems on a M-4700? #6
My favorite source is Ronnie Bowman at Keller Brothers Kubota (website is Tractorsmart.com). He has been a great resource for TBN members for years - always goes the extra mile to make sure you get the right parts and supporting information. If you call him with your serial number he'll hook you up with the right manual and any supplements or revisions.
Ronnie Bowman
TractorSmart.com is your online source for Kubota online parts.
Phone 717-450-1250
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
2022 EZ-GO ELITE...
2025 TP25 25in Hydraulic Post Puller Skid Steer Attachment (A64553)
2025 TP25 25in...
Club Car Emergency Cart (A64557)
Club Car Emergency...
Man Basket Boom Lift Attachment (A64553)
Man Basket Boom...
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
