3pt lower lift arm connection points break?
   / 3pt lower lift arm connection points break? #1
VroomVroom
Platinum Member
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
We always had an old farmall, so little experience with the 3pt hitch. I was wondering if people have bent or broken the shafts the lower lift arms attach to on the tractor. I'm thinking of making a blade or subsoiler, but I would imagine that could cause much impact forces on these, they dont look the largest, and if so can you replace them....
   / 3pt lower lift arm connection points break? #2
Most are stronger than you might think and operate in tension which doesn't require them to be very large to get the job done. Replace them? Sure, I would suggest that if you had the need to consider top n tilt hydraulics instead of screw adjustment OEM parts.
   / 3pt lower lift arm connection points break? #3
Just remember that the tractor and 3PH are built for pulling forward, not pushing in reverse.
Although breaking 3PH components isn't too common, the majority of the breakages were when pushing in reverse (hitting an immovable object when pushing snow, for example).
This isn't to say not to push...just use some common sense if and when you do...
1995 Ford F-800 Water Truck (A50860)
1995 Ford F-800...
Auger (A50860)
Auger (A50860)
2015 JEEP Compass (A50324)
2015 JEEP Compass...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2016 Cadillac XTS Sedan (A48082)
2016 Cadillac XTS...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
