3pt lift levers
   / 3pt lift levers #1
KURLY
NH TN65
good day to all. I have a TN65. on the right side of my seat is 2 levers that work the 3pt lift. one lever is a hold i assume and th eother works it. they are getting extremely tight. i am learning on tractors still as this is my first one so I have to ask are these levers suppose to be greased and if so where at? would they have nipples for a grease un or somewhere simply to rub greae on to eliminate the friction?
any help is appreciated, thanks.
   / 3pt lift levers #2
I would guess that one lever is the position control and the other is the draft control. I can't speak to your tractor, but mine has a grease zerk on the linkage for the 3-point control lever. Try following the lever down to its linkage point and seeing if you can find a zerk.
   / 3pt lift levers
Thanks josh and sorry for the long reply. I work out of town and do not always have access to a computer but do appreciate it.
I did get to look at it weekend before last and I couldnt find the grease fitting anywhere. could have been possibly over looking it but simply didnt see one. the 2 levers goes thru the sheetmetal and there is a knuckle kinda i guess you would say and it seems the friction is there. the linkage leaves theose knuckles and travelks to the main housing for the rear end. so its only like 10-14 inches to actually follow. i hit it with some wd40 but only seemed to relive it for a second. will be back to the tractor this weekend and intend on looking real good again. i washed it down good last time so i could see fine so dunno. may try ot take that piece apart where the 2 levers go into just below the sheet metal. thanks for yor suggestion.
Informational Lot - Financing (A53472)
Informational Lot...
2007 Chrysler Pacifica SUV (A51694)
2007 Chrysler...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
CHAMPION 3" CHIPPER (A51248)
CHAMPION 3"...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
